fixing torodial xformers to a chassis
Old 30th May 2012, 09:51 PM   #21
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by Rundmaus View Post
What you call 'horse ****' is basic electrodynamics / transformer theory. Please go back to 'Start' and read the basics.
A closed conductive loop around the core (formed by the bolt and the conductive chassis) will act as a single, low-resistance turn, effectively shorting out the transformer, as AndrewT and SY stated correctly.
Andreas
...and you don't understand basic magnetic theory. The effect you are so concerned about only concerns magnetic materials, like steel. So, maybe you should re-read transformer theory again.
Old 30th May 2012, 09:54 PM   #22
On Hiatus
SY's Avatar
No, an unintentional shorted turn only needs to be conductive to cause a major (smoke, flames) problem. If a nonmagnetic conductive mounting bolt touches top and bottom of the case, BOOM. Basic magnetic theory.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th May 2012, 09:56 PM   #23
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
fixing torodial xformers to a chassis Send a message via MSN to AKN
dirkwright,
You really need to rethink.
/ Anders
Old 30th May 2012, 10:12 PM   #24
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
And how comes that a voltage appears in the non magnetic secondary copper wire windings?
Old 30th May 2012, 10:26 PM   #25
dirkwright's Avatar
Because the copper winding is wrapped around a STEEL core.
Old 30th May 2012, 11:26 PM   #26
On Hiatus
SY's Avatar
So is the accidental shorted turn. Will a sketch help?
Old 30th May 2012, 11:26 PM   #27
pooge is offline pooge  United States
Dirk, it's not conducting magnetic energy. The "magnetic energy" induces a current into the shorted turn possibly formed by the bolt and the other, i.e., chassis elements. It's the same effect as if you took the ends of the secondary winding and connected them together.
Old 31st May 2012, 02:14 AM   #28
godfrey is offline godfrey  South Africa
Originally Posted by SY View Post
Will a sketch help?
Only if somebody looks at it and thinks about it. What are the odds of that happening? I reckon the closest you'll get is a "Whatever, I don't care!" response.
Old 31st May 2012, 03:07 AM   #29
dirkwright's Avatar
Yeah, thanks. I finally figured it out. Everyone else just said "look it up". That's one way to really **** me off.
Old 31st May 2012, 11:45 AM   #30
dirkwright's Avatar
I'm sorry you feel that way. One thing that is clear to me is that if someone really knows what they are talking about, they can explain it in a clear, precise, and succinct way. No one did this up to the one post where I finally understood what everyone was talking about. It appears to me that they do not understand what they are talking about if they can't explain it. So, when someone says "just go look it up". or "you're wrong", or "that's the way it is", then that really doesn't help me at all and it just becomes more and more frustrating for me to try to understand.
fixing torodial xformers to a chassisHide this!Advertise here!
torodial transformer question east electronics Solid State 6 18th December 2009 07:44 AM
Output regulator after torodial transformer? freestylez Power Supplies 9 25th June 2009 01:46 PM
torodial transformers? monomonster Parts 23 17th October 2005 08:48 AM
Torodial Tranformer Calculation JanDH Parts 34 28th December 2003 02:34 PM
