fixing torodial xformers to a chassis
Old 30th May 2012, 08:42 AM   #11
R.I.P.
Originally Posted by barrymagrec View Post
Yes - make sure that it`s fitted the right way round though or it can pull out with the weight of the toroid - I`ve seen this happen after kit has been shipped imperfectly packed.
This point has been raised before.
A back to front rivet nut has very little strength.
regards Andrew T.
Old 30th May 2012, 10:14 AM   #12
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by AndrewT View Post
Any conductive material will short out the transformer.
Steel is actually a bad conductor compared to aluminium. Copper and silver are even better conductors.
Carbon fibre is a bad conductor, but it will still short out the transformer.
Unless you can provide proof, this is complete horse ****.
Old 30th May 2012, 10:15 AM   #13
dirkwright's Avatar
It has plenty for normal use when installed in reverse. Unless you have actually done it, then you don't know what you're talking about. I have, and they are plenty strong enough.
Old 30th May 2012, 10:20 AM   #14
R.I.P.
Members,
sort the wheat from the chaff, i.e. believe what you want.
regards Andrew T.
Old 30th May 2012, 10:27 AM   #15
reapersdirge is offline reapersdirge  Australia
very infomative. thanks to everyone. cheers!
Old 30th May 2012, 11:56 AM   #16
6J6 is offline 6J6  Australia
If you aren't using a riv nut (like me), it's a good idea to insulate where the bolt passes thru the chassis, and where the nut tightens on the bottom. Nylon washers and nylon tubing over the bolt works well.
Just prevents any possibility of creating a shorted turn scenario. As the top plate and the chassis act as cheeks, and the rest is history.
6J6.
Old 30th May 2012, 12:29 PM   #17
On Hiatus
SY's Avatar
Originally Posted by dirkwright View Post
Only if it's steel. It doesn't make a damn bit of difference otherwise.
Or any other conductor- the thing to avoid is an unintentional shorted turn.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th May 2012, 05:34 PM   #18
barrymagrec is offline barrymagrec
Like I say, I have seen it happen. Transformer rolling around in the case. Believe it or not - makes no odds to me.
Old 30th May 2012, 07:25 PM   #19
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
What you call 'horse ****' is basic electrodynamics / transformer theory. Please go back to 'Start' and read the basics.
A closed conductive loop around the core (formed by the bolt and the conductive chassis) will act as a single, low-resistance turn, effectively shorting out the transformer, as AndrewT and SY stated correctly.
Andreas
Old 30th May 2012, 08:00 PM   #20
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
fixing torodial xformers to a chassis Send a message via MSN to AKN
If one creates a shorted turn, place a shoulder washer in one end of the bolt. Problem solved
/ Anders
fixing torodial xformers to a chassisHide this!Advertise here!
torodial transformer question east electronics Solid State 6 18th December 2009 07:44 AM
Output regulator after torodial transformer? freestylez Power Supplies 9 25th June 2009 01:46 PM
torodial transformers? monomonster Parts 23 17th October 2005 08:48 AM
Torodial Tranformer Calculation JanDH Parts 34 28th December 2003 02:34 PM
