snubber designing for full bridge power supply
Old 28th May 2012, 02:56 PM   #1
8409513 is offline 8409513
Default snubber designing for full bridge power supply
Hi, I want to design snubber for full bridge power supply. I don,t know what to do!!!! what snubber is suitable? and how it will be connect to mosfet? whai is it's calculation?plz help me with this.
Old 28th May 2012, 03:27 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Hi boy. Normally, snubbers canīt be calculated., they are only aproximations.. I read some literature at the respect, and in conclusion, the trouble is easily solved empirically in the circuit.
The best way is the following: with the circuit working in normal conditions, measure the frequency of the ringing to be eliminated. So, try small capacitors in parallel to the primary of the transformer to tune to 1/2 such frequency, or any other frequency of your interest. Then, start to add small resistor in series with the capacitor, and go increasing its value to damp completely the ringing. Be careful with high voltages in the circuits and the power of the resistor, which obviously must be non inductive.
If you want, you can distribute the cap and the r in two MOSFETīs, or in the 4 ones.
Good luck.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 28th May 2012, 10:37 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Jim Hagerman at Hagerman Technology has an old paper:
"Calculating Optimum Snubbers"
http://www.hagtech.com/pdf/snubber.pdf
Kevin
Old 4th June 2012, 11:55 AM   #4
Fanuc is offline Fanuc  United Kingdom
Default Snubbers
Thanks for the link to that article SpeedSkater.
It appears to me now that it's the RLC resonant tank circuit that is the problem (ie. using soft recovery or shottky diodes is mostly irrelevant and ineffective.)
Toriodals are wideband also. Huge reservior capacitor's do not help.
It's hard to get the data on transfromers unfortunately, but the author's suggested methods to measure transformer inductance and interwinding capacitance do not seem that difficult.
At least we do not need the impedance network part!!
Kevin
snubber designing for full bridge power supplyHide this!Advertise here!
How to schematic switching power supply full bridge ? cakum Power Supplies 0 1st September 2010 08:56 AM
Power Supply Designing using LM317, RC-snubber okina Power Supplies 4 12th September 2005 02:17 AM
BrianGT snubber power supply upgrade PMeade Chip Amps 3 7th May 2005 01:45 AM
Power Supply Pumping with full bridge edogd Class D 1 3rd February 2005 08:02 PM
