12VDC power supply
12VDC power supply
Old 30th May 2012, 05:51 AM   #11
jitter is offline jitter  Netherlands
jitter's Avatar
Originally Posted by manner View Post
Dear All,
I need at least 2A.
I measured the DC voltage directly at the output terminal without any load.
The input voltage was 220V at that time-stepped down to 15V via a toriodal transformer.
There is already a voltage regulator circuit in situ but the DC voltage was 19V instead of 12V. Is there any simple way to step down the voltage without rebuilding the whole circuit? Can I add resistors across the output terminals to bring down the voltage?
What kind of voltage regulator is in now?
Does it need a minimum load to function properly?
If so, what happens to the voltage when you apply that minimum load?
If that does the trick, the question to you last answer should be "yes", provided you use resistors that can deal with the power they're dissipating.
12VDC power supplyHide this!Advertise here!
schematic supply from 12vdc to 24vdc Ground Zero Car Audio 6 27th August 2011 04:26 PM
Anyone tried this 12vdc 1A supply? dublin78 Power Supplies 1 11th June 2009 04:27 PM
12vdc power distro lovitz Everything Else 3 30th April 2008 05:46 PM
Simple BIG 12VDC supply ideas wanted MadMutt Power Supplies 29 23rd October 2007 11:47 AM
Best way to power a 12vdc fan from 25vdc for an Aleph30 hifimaker Pass Labs 16 16th December 2005 08:36 PM
