smps switching frequency and noise
Old 27th May 2012, 08:17 AM   #1
soundnovice is offline soundnovice
Default smps switching frequency and noise
hi
arjen helder ebay lists a smps power supply
Switchmode Power Supply 11-14 volts ADJ 3.5 A power max | eBay
the description says that the switching freq. is 50khz so noise is not an issue.
for t-amp, will this smps power supply give good results or atleast comparable with linear supply?
or do u prefer linear supply as a better option?
Old 29th May 2012, 08:02 PM   #2
Austin Translation is offline Austin Translation  United States
Austin Translation's Avatar
Send a message via MSN to Austin Translation smps switching frequency and noise
50khz noise can and will get amplified by a tube amp you just won't hear it. It will rob power and can make the output tranny run hotter. Like a little AM radio station... It can and probably should be filtered.
Linear supply is heavier and less efficient but bullet proof and will probably never break where a smps can fail at any time for no reason at all but is well regulated lightweight and low impedance.
Old 30th May 2012, 01:39 AM   #3
i will not be bothered about heat issues, as long as it can provide clean power. so with an external regulator, can this 50khz noise from smps be removed? in that case can i safely assume that the clean power i get from such a smps is as noise free as i would get from a well designed linear supply?
Old 30th May 2012, 01:57 AM   #4
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The audibility of the noise per se is of less consequence than the effects of non-linearities caused by premature conduction of PN junctions AND the way in which smps noise can effect clock and comparator operation. Analog Devices has a paper on this.
Old 30th May 2012, 05:36 AM   #5
jitter is offline jitter  Netherlands
jitter's Avatar
You could probably suppress it to a very low level, but fully removing it seems unlikely. Not sure that a lineair voltage regulator will do this very well. My money would be on a good low pass filter.
Perform a search on this forum, you might find useful threads dealing with this issue.
smps switching frequency and noiseHide this!Advertise here!
How to identify max switching frequency of a MOSFET jegandren Power Supplies 8 17th July 2008 07:12 PM
Question: SMPS switching frequency with 41Hz Amp4 DVBjunky Class D 34 18th March 2008 08:47 AM
mhz switching frequency lumanauw Class D 40 24th December 2007 01:48 PM
Hysteretic self-oscillating amplifier with constant switching frequency sovadk Class D 8 18th November 2006 10:44 AM
Hysteresis Controller with constant switching frequency TOINO Class D 4 18th June 2006 08:34 PM
