1kw 28khz % 90 eff with shortcut and thermal protect.
#2 |
corrected errors
#3 |
looks good, can't say I can find anything wrong with schematic
you can probably get away with one less primary wire and use one or two more for secondary, where the current is higher |
#4 |
Hey Luka, do you know of a schematic with the same voltage output and current but with 110 input voltage? Or how this one could be modified to use 110?
Thanks ![]() Never give a Systems Analyst a screwdriver or hammer
#5 |
thanks 400kg,
If possible, try to analyze this circuit, to beginners and those who are wanting to learn your skills and experiences . If you guys olso have time,please do this. thanks, |
#6 |
All you would need to change is make link in the right place to make voltage doubler on input and that's it... just like PC supply have switch, same thing, same place, one position is for 110 other (no link) is for 230
#7 |
Hi.We have 3c85 material ,etd54 and frequency is 28khz.
Can we estimate how much power max can i get from this design and what should be the primary turn number and lead diameter?Thank you |
#8 |
I forgot to say.Duty cycle is 45%
#9 |
#10 | |
thanks luka May be equivalent in 3c85 n87? |
| Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted | tiefbassuebertr | Analogue Source | 30 | 21st October 2012 07:01 PM |
| Is this really an SMPS? | TylerDurden | Power Supplies | 9 | 14th July 2011 11:03 AM |
| need little help with smps | uglykid | Power Supplies | 4 | 11th November 2010 04:56 PM |
| Another smps | dexter2003 | Power Supplies | 5 | 11th November 2009 12:43 PM |
| Smps | hugefathead | Solid State | 8 | 5th March 2004 03:44 AM |
