Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd May 2012, 08:20 AM   #1
Default PSUDII simulation vs reality
I have a tube rectified LC-LC-LC power supply that I designed with PSUDII. I took care to use have enough resistance and large enough capacitor to avoid the initial voltage spike. Not only I do get the spike, I get a pretty big one (upto 180+V, takes a few seconds to stabilise to 100+V).
I was told that the initial spike can be an indication that the PSU would ring.
I wonder if it is normal? Or is there something wrong? The chokes I used are pretty cheap. And the tube rectifier heater is starved (5.4V instead of 6.3V) and probably because of that I also get quite a bit lower output than simulated.
Old 22nd May 2012, 09:06 AM   #2
DF96 is offline DF96  England
PSUs with chokes can ring. Difficult to say more than that without a circuit diagram.
Old 22nd May 2012, 09:54 AM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
zip and attach PSUD file here
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 22nd May 2012, 02:19 PM   #4
Here it goes.
I put the first choke as 1083 ohms, it is actually 250 ohms with 833 ohms worth of resistor in series.
The last cap of 80uF is made up of 2x40uF in parallel.
File Type: zip B+ Supply.zip (278 Bytes, 37 views)
Old 22nd May 2012, 03:14 PM   #5
Sorry, my PSUD2 won't open it.
Old 22nd May 2012, 03:37 PM   #6
This is how it looks like.
Old 22nd May 2012, 03:43 PM   #7
SY's Avatar
So L1 really has that high of a DCR?
To check stability, use a CCS as the load, set to the expected current for the intended load. Then use the "step" option to have it step up or down by (say) 20% after 10 seconds or so. See what happens.
If there's a sucker born every minute, where do the rest of them come from?
Old 22nd May 2012, 03:57 PM   #8
I suspect what is happening is that the LC filtering means that the initial choke input stage sees very little current draw at first, so its voltage shoots up. Once things stabilise it does what you expect. You won't see any spike on the output with PSUD2 because your load in the simulation draws current straight away. Plot V(C1) to see a spike (my prediction - I could be wrong).
Old 22nd May 2012, 04:19 PM   #9
AndrewT is online now AndrewT  Scotland
C1 and C2 and C3 ensure that the first L sees a substantial current load from start up.
That should prevent a spike due to the L not seeing a significant current load for choke input to operate as expected.
Old 22nd May 2012, 04:23 PM   #10
Before L1 I put a bunch of resistors in series to cut down the voltage to where I need it, I lumped the total resistance together with L1.
The load is set as CCS. I tried stepping up or down, they look smooth, no spikes.
Tapped Horns - Simulation VS Reality Patrick Bateman Subwoofers 59 28th December 2011 01:49 AM
PSUDII Question Captn Dave Tubes / Valves 11 2nd March 2011 04:54 PM
PSUDII transformer question rotaspec Tubes / Valves 13 25th March 2010 05:58 PM
hybrid graetz in PSUDII JoshK Tubes / Valves 1 27th January 2007 01:50 AM
Your thoughts on simulation compared to reality Mr Evil Everything Else 12 1st March 2005 03:45 AM
Copyright ©1999-2013 diyAudio
