LM317 CCS in DC Power supply - Does HF performance matter?
Old 15th May 2012, 06:44 AM   #1
skibum is offline skibum  France
Default LM317 CCS in DC Power supply - Does HF performance matter?
A couple weeks or so ago I had some questions about a CCS for a DC power supply.
Janneman helped me out an I am currently using a LM317 for a CCS in my DC Power supply.
One of the things I have been reading (in this forum and others), is that a CCS using a LM317 (or any LMxxx), is "not very good at high frequency".
If the LM317 is being used as a CCS in a DC power supply does this matter?
I am using a LM317 for a CCS in a DC Power supply for a DAC. The DAC has oscillators at 20+ MHz and BCK frequencies above 10MHz, ect. Plenty of high frequency stuff.
So I am wondering if it matters or not since in this case the LM317 is supplying DC current in a DC power supply?
Thanks!
Old 15th May 2012, 07:53 AM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
You again!
Regulators 101: ALL regulators are filters (just like all amps are filters), meaning they all lose performance above their roll-off frequency. The 317, or any other regulator, integrated or discrete, is no exception. So, the hf performance of ALL regulators deteriorates at hf.
That means that ripple rejection, output Z etc gets less at higher frequencies.
That's the reason why you see all these graphs bending upwards (or downwards, depending on what the data is) from a certain frequency.
The bummer is that, because all amps are filters too, the Power Supply Rejection Ratio of amplifiers also deteriorates above their Fc. So you get hit doubly: the supply gets worse, and the amp's ability to reject supply junk also gets worse.
There's no sure-fire solution to this, except that with smart circuit design you try to juggle supply performance, turn-over frequency and amplifier PSRR to get the best possible performance as a system.
This is the area where the good designer earns his next installment on the Lexus
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 15th May 2012, 01:36 PM   #3
Yep, it's me again!
They LM317 worked great as far as consistent current output, but it just did not sound as good.
I tried using a cascode DN2540 with the LM317 that I saw in Walter Jungs CCS articles. The problem I had with that is that my supply voltage is 9.5 volts. Walters circuits were all done using 18 volts. I could only get about 1.9 volts maximum for the (Vo-Vin) of the LM317 with the DN2540. The minimum Vo-Vin for the LM317 is about 3 volts.
Even with this low Vo-Vin it sounded much better than just the LM317 on its own.
I have been reading about current limiting diodes and might try to feed the LM317 with one of those. According to the data sheet they have a pretty high impedance up to at least 200KHz.
Any other ideas would of course be welcome!
Old 15th May 2012, 05:57 PM   #4
Performance of any regulator is very different for a continuous non varying current demand cf. a step varying current demand.
Any step in current demand whether from 0% to 100%, or from 100% to 0%, or from 53% to 55% is effectively an HF regulation problem looking for an HF solution.
regards Andrew T.
LM317 CCS in DC Power supply - Does HF performance matter?Hide this!Advertise here!
Does Voltage Divider Impedance Matter with LM317? audiogeekess Power Supplies 11 8th December 2011 11:29 PM
LM317 or TL783 for a 0-60V power supply? beppe61 Power Supplies 26 22nd September 2010 09:39 AM
LM317/Power supply help? djmike Chip Amps 15 6th October 2008 05:49 PM
Supply capacitance reduces hf performance? Is that true? akunec Chip Amps 101 10th December 2005 06:54 PM
Copyright ©1999-2017 diyAudio
