I have a transformer with 0-115-230V on the primary and 0-110-230V on the secondary.
If I feed 230V mains on the secondary's 110-230V taps to get 220-0-220V on the primary, how likely is catastrophic failure? I imagine a power transformer designed for mains use would be build with a healthy dose of headroom. But I still want to live. ![]() On the same topic, what if I connect 2 identical of the said transformer, both primary wired as usual and both secondary wired in series (and in phase) to get 230-0-230V? Thanks.
#2 |
put double the rated V on a pwr xfmr winding (strictly speaking its the V*T product) and it will certainly result in core saturation - huge current draw, best case is fuses blowing, breakers popping
the 2 xfmr option can work, if you need higher rectified DC then diode-capacitor doubler topology may work with single xmfr |
#3 |
Thanks.
![]() I am using tube rectifier, so I am trying to avoid bridge (lots of tubes) or voltage doubler (capacitor after rectifier). If the two transformers trick works that would be great as I already have them. |
#4 |
Two transformers will work for your application.
Frank |
#5 |
Thanks again, glad to know that.
#6 | |
#7 |
Thanks for the info, obviously I haven't been to that planet.
Glad that I asked.
#8 |
that's OK some of aren't planning to visit anywhere vacuum tube rectifiers are held in esteem when SiC Schottkys covering the required I,V ratings exist
| I think my transformer's voltage is too much for LM4780? | TheLaw117 | Chip Amps | 22 | 14th June 2011 05:59 AM |
| Confused about a transformer's power rating | Atilla | Power Supplies | 11 | 16th March 2009 11:18 AM |
| Exceeding electrolytic cap rating | Pierre | Power Supplies | 22 | 16th September 2007 10:53 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 06:44 AM |
| How important is the transformer's VA rating for a gainclone? | Bricolo | Chip Amps | 73 | 3rd August 2003 04:55 PM |
