#21 |
Revised schematics: some values changed, ballast resistor R17 added.
#22 |
If you use a series zener or even just an LED on the output of the opamp you can supply the opamp from the final regulated voltage. That improves all regulator performance areas.
jan didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! Last edited by jan.didden; 31st May 2012 at 05:21 PM. |
#23 |
You will have to "sort out" all the traces that connect to Ground and similarly all the traces that connect to +ve.
#24 | |
Jung super regulator operate in a different mode, pass transistor is biased from a constat current source and the op amp modulate this current with error signal. BTW the decoupling network R5-T2-C2 improves significatively PSSR of the op amp, more than 30 db in my simulation, not much different, I believe, than supply op amp directly from the final regulated voltage. Andrea |
#25 | |
Current sensing resistors R14-R16, per example, need to connect with traces as short as possible to the output of the regulator, that's the reason I'll use a 4 terminal resistor. Andrea |
#26 |
Follows the final schematics of two versions of regulator: HG version is a 6Vdc 700mA with hi-grade components, SG is a 5Vdc 700 mA with standard components.
I attach some analisys of HG simulated circuit. I'm going to order components to build two prototypes. Andrea |
#27 | |
' jan
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#28 |
This might be slightly off-topic, in a way, but is probably worth thinking about.
What about simulating with digital loads (e.g. pulsed current draw), and including power and ground rails' impedances, and looking at the voltage across the load? Then everything will depend on the decoupling capacitors at the load. Typically, it seems that people expend much effort on a power supply but not enough effort on the effects of the impedance of its connections to the load, and the decoupling capacitor networks at the load. What matters most is what happens at the load, not at the power supply output. Even with a truly-perfect power supply, any load drawing transient currents through inductive power rail conductors (or planes) will produce voltage disturbances on power/gnd rails (or planes), at the load, with amplitudes of voltage disturbances dependent almost solely on decoupling capacitors and load's transient-current demand's amplitudes and timing. Decoupling caps at each load are like small point-of load power supplies, for transient current demands. (With a known maximum change in current that might be needed, di, and a known minimum time during which that might have to occur, dt, and a desired maximum voltage disturbance on the power rail (at the load) due to the transient current, dv, which we get to choose, the needed minimum decoupling capacitance can be estimated with C = di dt / dv. There is more to consider, and different ways to look at it, but that, or double that to be safe, is better than just guessing. [You do also have to calculate an estimate of the inductance that can be tolerated in the connections of the caps to the load, to determine their maximum acceptable length and whether or not multiple parallel caps need to be used instead. Simplified way would be L = dv dt / di.]) What is the actual goal? Isn't it for the power pins of the active devices to receive (or give) the current they demand, exactly as needed (amplitude vs time), while the voltage is maintained at a constant value? (Or is the constant voltage value even always necessary, as long as the device pin's current's amplitude vs time is exactly correct?) I guess low-noise steady-state stuff is relatively easy and well-known. But transient current demands can ruin your best design if you haven't paid very close attention to the rail impedance effects and used optimal decoupling networks very near the points of load. It's still just about as important when using full power and ground planes. Without power and ground planes: Best way would probably be to have zero-length power rails and a fantastic PSU. Second-best might be to use multiple parallel copies of each voltage and ground rail (lowering overall impedance by paralleling paths, i.e. by having no mutual self-inductance), each path with its own caps at both load and PSU ends and paths all connecting only at a single point at each end. Third best is probably the usual way but to also carefully design the decoupling capacitor networks. You can simulate all of those. Probably nothing else is really worth trying, if performance is critical. Even when using power and ground planes, with many dispersed decoupling caps around chips, you would probably also want to disperse the power and ground connections to the planes (which is sometimes forgotten), with fully-parallel connections all the way back to the actual main supply and ground points. You could probably simulate a best-case scenario for that, by assuming all decoupling cap currents take separate paths (so no mutual inductance makes inductance reduce fully due to parallel paths), and calculating the overall impedance of the parallel paths. Sorry to have blathered-on about all of that, for so long. Cheers, Tom |
#29 |
In your simulations, you should probably also try including estimates of the parasitics, of both the components and of the conductors. It will give a much-more-realistic simulation (although slower-running), and could also help you to find out which, if any, conductors' lengths might be critical to keep short.
For a first approximation, you can usually use .001 Ohm of series resistance per inch of PCB trace and 30 nH of series self-inductance per inch. (Obviously you might have to guess at, or estimate, the PCB trace lengths, for now.) If you don't know the parasitic series inductance of a capacitor, then at least include 30 nH per inch of lead spacing. And many resistors have roughly 0.2 pF or so of parallel parasitic capacitance. The parasitic series resistance (ESR, or Equivalent Series Resistance) of electrolytic capacitors changes quite-significantly, with frequency. If ESR is not given at the frequency you need for simulation, you can usually convert it, using the assumption that the dissipation factor (tan(delta)) varies by much less, versus frequency, usually less than 100% overall. They are related by tan(δ) = 2 ∙ π ∙ f ∙ C ∙ ESR which can be used to get tan(δ) if you know only the ESR at a particular frequency. Then you can solve for ESR and re-calculate the ESR for different frequencies, assuming that tan(δ) doesn't change by much: ESR = tan(δ) / (2 ∙ π ∙ f ∙ C) There is usually also a leakage current spec, such as "I = .01 C V or 3 uA, whichever is greater", which should be used to calculate the parasitic parallel resistance, i.e. V/I = R = 1 / (.01 C) . Although they might be too cumbersome, and are probably unnecessary to use for this project, I should mention that there are ways to make spice models of electrolytic capacitors with ESR modeled such that the effects of any frequency are included. For example, see Cornell Dubilier Plug-In Thermal / Life Calculator , which also nicely displays how various electrolytic capacitor parameters change with temperature and frequency (and will automatically provide a frequency-dependent spice model for any of their electrolytic caps). |
#30 | |
Use the LM833? It goes from +- 5v to +-18v. I ugess you wouldn't have to worry about low voltage spikes. ; ) Sync
Give the Gift of Music |
| Regulated power supply | meanman1964 | Everything Else | 13 | 9th April 2007 02:50 AM |
| Regulated power supply | akunec | Chip Amps | 3 | 5th November 2006 10:27 AM |
| Regulated power supply | croccodillo | Tubes / Valves | 2 | 2nd November 2006 10:47 AM |
| regulated power supply | adason | Swap Meet | 1 | 11th December 2005 06:32 PM |
| regulated power supply | yugaaa | Solid State | 17 | 28th January 2003 02:39 PM |
