The Well Regulated Power Supply
Old 5th June 2012, 03:08 PM   #41
Telstar is offline Telstar  Italy
Originally Posted by andrea_mori View Post
The project is op-amp based, so I investigated if there was reason to build a discrete operational amplifier, but finally I concluded that it is better to use a monolithic OA, such as AD797, AD825, OPA627, OPA132 or so.
Have you read Jung's article dated 2000? The AD825 is the preferred OPA for voltage reference in its regulators.
Originally Posted by analog_sa View Post
I have little doubt that at least the requirements for analogue circuit regulators are very different from those meant to power digital circuits.
I agree 100%.
I agree with you that different circuits requires different power supplies.
Btw if you had an ideal supply you could use it either for analogue than digital circuits. Obviously ideal supply does not exists and I have no claim to build it.
It can be done but it would be a waste of money.
I prefer to have several independent PSU than to connect several lines to a SOTA one.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 5th June 2012, 04:18 PM   #42
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
I have read Jung's article, but I'm designing a series regulator operating in a different mode. As you can see in the schematics I do not use the opamp to modulate a current source like in Jung Super Regulator, rather the pass transistor is modulated directly from opamp error signal.
BTW I choose LT1028 that has superior performance than AD825, IMHO. LT1028 shows impressive electrical characteristics:
input noise voltage: 1nV/sqrt(Hz)
PSSR: 133 dB
GBW: 75 MHz
Only slew rate is lower than AD825, but don't forget that a shunt regulator follows the series regulator in my design, so I think relatively slowly opamp such LT1028 (11V/us) do not affect the final regulation because shunt section improves transient response.
Old 5th June 2012, 04:30 PM   #43
Originally Posted by qusp View Post
hmm, so the opa637 is for higher voltage versions yes? its really not very happy with low gain in my experience it needs to be 3-4x or above, certainly not unity
Maybe there's another way to implement OPA350 in any case, low and high voltage, let opamp operate always at low voltage like in the attached schematic.
Old 5th June 2012, 04:46 PM   #44
PSSR: 133 dB
GBW: 75 MHz
I hadnt seen the schematics when I posted. Your circuit looks good and does not seem over-expensive for a high quality digital PSU. Glad you ditched the inductors I'm looking forward to the PCB.
BTW, are the diodes schottky?
Old 5th June 2012, 05:22 PM   #45
Diodes are FRED epitaxial with 35 ns trr.
BTW you can use shottky like SB3100, MBR3100 or so.
Old 7th June 2012, 04:16 PM   #46
Default Question
In order to use OPA350 also in regulator that output a voltage greater than 5.5V we have to reduce its power supply voltage to 4/5V.
After some simulations I found two way as in the attacched schematics: first simply with 3 red LEDs, the second more complex with TL431.
I would like to know which one you favor, or if you have any other suggestion.
Thanks all
Andrea
Old 7th June 2012, 07:17 PM   #47
dtproff is offline dtproff  United States
Thanks all
Andrea
TL431 for the thermal stability of its bandgap reference.
Tony
Old 8th June 2012, 08:16 PM   #48
Gootee,
looks like they have not read your two posts. They are still worried about the opamps.
Good decoupling at the load will reduce the slew rate of the step response on the supply rails and that reduces the need for ultra high speed opamps. They don't seem to see the connection.
regards Andrew T.
Old 8th June 2012, 09:43 PM   #49
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Thanks all
Andrea
I would not use such a simple emitter follower. I would use a 3-pin 5V regulator for the opamp supply: more accurate, lower impedance, better rejection. With an electrolytic on its output.
jan didden
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 8th June 2012, 09:55 PM   #50
jan didden
So I have to ask... You are already using a part that has 90dB CMRR, how much quieter do you need to be?
This isn't a slam, I'm just curious.
Tony
The Well Regulated Power SupplyHide this!Advertise here!
Regulated power supply meanman1964 Everything Else 13 9th April 2007 03:50 AM
Regulated power supply akunec Chip Amps 3 5th November 2006 11:27 AM
Regulated power supply croccodillo Power Supplies 2 2nd November 2006 11:47 AM
regulated power supply adason Swap Meet 1 11th December 2005 07:32 PM
regulated power supply yugaaa Solid State 17 28th January 2003 03:39 PM
