Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th May 2012, 09:38 PM   #1
Default why not 3 phase?
This question is bugging me from time to time,
why shouldn't 3 phase powersupply be used for high end audio amplifiers?
Supposedly smoother DC could be achieved, seems quite reasonable.
Might some PA system be using this setup, I'm not realy into those.
Any opinion ?
Old 9th May 2012, 09:47 PM   #2
3 phase power is rarely available. You want "Y" and most is Delta. So the market would be tiny.
Old 9th May 2012, 09:50 PM   #3
zigzagflux's Avatar
Sure, three phase will provide for a lower ripple power supply, all things being equal. But reasonable it is not. To be done properly, you need either a three phase transformer, 3-single phase transformers, or 2-single phase transformers connected open delta. More iron equals more cost.
Then there is the issue of availability, which for US residents is less than 1% of the population. Utilities normally will not install a three phase service unless kW demand is a minimum value. Chances of getting three phase residential service is almost nil.
Better off with a bigger DC choke than using three phase. Permanently installed high power systems, such as auditoriums, churches, arenas, etc would be fine with it; I'm guessing most of those are 208V.
Old 9th May 2012, 09:52 PM   #4
zigzagflux's Avatar
Nothing wrong with delta; three phase rectifiers only require three legs- they don't use the neutral.
Old 9th May 2012, 10:00 PM   #5
asmith is offline asmith  United States
Default Some amps do.
Some of the BIG Crown amps do run on 3 phase. Seems like they made one rated for 10k RMS that had to be run that way.
Old 10th May 2012, 01:15 PM   #6
I would expect PA equipment to come with the option to use or be adapted to 3phase supply.
I further suspect that some PA equipment only comes ready wired for a 3phase supply.
Old 10th May 2012, 01:26 PM   #7
KatieandDad's Avatar
MOD always use three phase.
Old 10th May 2012, 03:29 PM   #8
1% ????
3 phase 16A / phase is the standard here, while i do agree that some residents to not have 3 phase wall connectors. Quite a surprise actualy. I was thinking USA people like dish washing machines and sortha stuff that requires 3 phase usualy.
Old 10th May 2012, 04:31 PM   #9
jitter is offline jitter  Netherlands
jitter's Avatar
Ehm, if I'm not mistaken, residental buildings in the USA don't have the 3 phase system but the split phase system (Edison system) to get 110 V or 220 V.
See also this thread.
Old 10th May 2012, 04:40 PM   #10
Speedskater's Avatar
True, very few homes in the US have 3 phase power, only a few in mixed use neighborhoods even have the option.
8000 Volt 3 phase power entries my neighborhood, but only a single phase line goes down each street. Then a single phase transformer steps it down to 240 Volt center tapped.
Kevin
OLG Phase vs Output Phase Neutrality Solid State 18 29th June 2011 04:58 PM
INA134, balanced an unbalanced, normal phase and inverted phase CJ900RR Analog Line Level 1 30th March 2011 03:30 PM
Acoustic phase, electric phase,....phase ermes Multi-Way 6 27th November 2010 06:17 PM
KEF driver phase and the H-B generated phase dlr Multi-Way 11 24th April 2007 11:56 AM
dipole sub H-Frame, phase or opposite phase ? mbon Multi-Way 6 19th June 2004 08:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
