Maximum DC power for a Transistor before heatsink necesssary? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th May 2012, 03:12 PM   #1
skibum is offline skibum  France
Default Maximum DC power for a Transistor before heatsink necesssary?
Hello,
I have a NPN transistor that has 60mA of emitter current and Vce = 3.18VDC for a power of 0.18 watts.
The only specifications I can find on the data sheet are:
PD Total Device Dissipation(TC=25C) = 50 Watts
Derate above 25C = 0.4W/C
RθJC Thermal Resistance, Junction to Case = 2.5 C/W
It is a T-220 case.
I have attached a Power derating curve that is on the data sheet also.
For this example I feel that I am OK with out a heatsink because when I press my finger against the transistor it is just barely warm.
I just want to know how to do this for in the future.
How can I calculate at what power should I be using a heatsink?
Old 9th May 2012, 06:25 PM   #2
Loudthud's Avatar
You need to know the thermal resistance junction to ambient. For a TO-220 it's probably 50 to 60 degrees C per Watt. If it's not on the manufacturers' spec sheet, look for other parts made by the same manufacturer, or a similar part by another company. Then just figure the junction temperature based on power dissipation.
Old 9th May 2012, 06:47 PM   #3
A rule of thumb I use is 1.5 watts for TO220 . 1 watt for TO126 and 2 W for TO3P . Seems to work if there is ventilation . The printed circuit can dissipate heat if plenty of copper is connected with the transistor . I ran some BD 135 in pairs at 1.13 Watts for days with no problems . Another rule of thumb . If you can not hold on to them for 5 seconds they are too hot . Small clip on heat sinks cost very little money .
Old 10th May 2012, 01:07 PM   #4
I have pulled up an ONsemi MJE15032 because I knew it was rated at 50W when Tc=25C
The datasheet shows 2.0W when Ta=25C
Sometimes the manufacturer shows two plots on the P vs Tc/Ta graph. ONsemi show both.
Again some manufacturers show Rth j-c and Rth j-a for the two operating conditions of infinite heatsink or no heatsink.
All these forms can be used to determine the same de-rated SOAR.
eg.
50W @ Tc=25C gives Rth j-c = {150-Tc} / P = 125 / 50 = 2.5C/W for the infinite heatsink.
2.0W @ Ta=25C gives Rth j-a = {150-Ta} / P = 125 / 2 = 62.5C/W for the no heatsink.
You have 180mW and no sink.
Tj = {Rth j-a * P} + Tambient = {62.5 *0.18} + 40C = 51C. 51<<100 so OK.
You can re-arrange the formula to give Pmax = {Tjlimit - Tambient} / Rth j-a.
If you set your Tjlimit to 100C and Tambient = 50C then,
Pmax = {100-50} / 62.5 = 0.8W compared to absolute maximum of 2W when Ta= 25C
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th May 2012, 01:36 PM   #5
I remember doing all those calculations for a design once and getting nowhere . I didn't realize that the heat transfer to the heat sink is not ideal and doesn't happen in real life . I say when real power comes in double your estimate . We did this at work recently . The guys I work with are no idiots . The design was to be air cooled . Now we have a small fan as it didn't quite work out . This cost the project months because the boss didn't want a fan . It is the quietest fan we could find and comes on when needed . Some customers in Asia turn of the air con . It blows our devices up if 45 C in the room .
Old 10th May 2012, 02:07 PM   #6
Thanks Andrew
I will still do the finger test but it's nice to have an equation.
Old 10th May 2012, 02:11 PM   #7
I know if we get into trouble we have Andrew . I have many at work and I am lazy . I dig a hole and they get me out . I am the boss you know . It was me who didn't want fans .
Boss of projects that is . Not money boss thank goodness .
Power tube maximum current draw from a power supply razorrick1293 Tubes / Valves 4 4th November 2011 10:48 PM
Mica in Heatsink TO3 power transistor or no ? aldovan Solid State 2 6th June 2008 03:39 AM
Heatsink for two STK4050V in maximum power ElectroPower Chip Amps 2 24th July 2007 02:27 PM
For 35A rectifiers, what is maximum without heatsink geminni Solid State 10 18th March 2007 12:54 PM
isolating power transistor from heatsink Wagener Solid State 10 23rd May 2004 09:57 PM
Copyright 1999-2017 diyAudio
