Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th April 2012, 03:26 PM   #1
Default SMPS Help
Hi, I'm looking to build a SMPS for a class D amplifier. The supply needs to provide around 200V and 1-2A. Ideally it should be reasonably small (an inch or 2 high and up to 6 inches long).
I have made many fairly high voltage linear power supplies for valve amplifiers and a few other applications, but I am pretty new to switched mode amps and was looking for some guidance. I have done quite a bit of reasearch and found that the forward converter topology looks like a good starting point but all the existing designs I can find convert mains voltage down to something like 12V. Where is a good place to get the necessary high power parts from in the UK and does anybody have any ideas which might get my design progressing a bit better?
Old 25th April 2012, 03:52 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
As Abraham Pressman says in his book, the forward converter may be with one or two transistors conducting simultaneously. In both cases, the trouble will be a large output smoothing inductor. Appears that flyback topology is more recommended for HV supplies.
There is another thread with a same theme:
Choke formula - Marty Brown
Regards.
LW1DSE
Old 25th April 2012, 10:03 PM   #3
dangus is offline dangus  Canada
I would be inclined to start with a known good power supply, then rewind the transformer and alter the feedback voltage divider so as to get 200V instead of 5V. Or if it's for a car amp, same thing, except use a common amp that you have docs for.
Old 26th April 2012, 01:11 PM   #4
Thanks for the replies - sounds like quite a good idea to modify an existing supply. I've got a few books like Osvaldo recommended and they're proving helpful. I need to do some more reading around the topic for now I think.
Old 27th April 2012, 01:25 PM   #5
Default L6565
I´m planning to build a L6565 and STD7N60 quasi-resonant converter to test the performance of such a scheme.
LW1DSE
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 30 21st October 2012 07:01 PM
Using SMPS Aucosticraft Power Supplies 1 4th June 2010 07:14 AM
Smps rinox Power Supplies 0 2nd September 2005 10:05 PM
smps MV Car Audio 0 8th March 2004 03:40 PM
Smps hugefathead Solid State 8 5th March 2004 03:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
