Newb power/speaker questions
Old 23rd April 2012, 07:57 PM   #1
mossen is offline mossen
Default Newb power/speaker questions
Let's say you have an amp, and it delivers 50W into 4 ohm speakers. What would happen if you hooked up 8 ohm speakers to it? It would deliver about 25W, correct? So, less volume? What else? Will it run hotter/cooler?
What if you had a amp designed for 8 ohm speakers and you hooked up 4 ohm speakers to it? Could it potentially overheat since its delivering more power?
All else being equal, are low-impedance speakers generally better?
mossen
Old 23rd April 2012, 08:03 PM   #2
lduarte1973 is offline lduarte1973  Portugal
Banned
the amp will be cooler at with higher impedance (8ohm) since the load for the amp is easyer , with lower impedance (4 ohm) output distortion and heat will be higher
Newb power/speaker questionsHide this!Advertise here!
newb general questions mordante Multi-Way 9 26th August 2010 08:50 PM
Newb Questions mpw01 Multi-Way 7 4th March 2008 02:35 PM
I Got Newb Questions... Wyloch Multi-Way 1 28th February 2005 07:33 PM
Aleph X Newb Questions koolscooby Pass Labs 3 16th December 2003 03:04 AM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
