atx linear power supply newbie help
Old 23rd April 2012, 04:49 AM   #1
sofus79 is offline sofus79  Denmark
Default atx linear power supply newbie help
where do i get the pcb i need for such a build
Old 23rd April 2012, 04:57 AM   #2
and how do i know if lets say the transformer fits etc
Old 27th April 2012, 07:00 AM   #3
no one ??
Old 27th April 2012, 07:34 AM   #4
Boscoe is offline Boscoe  United Kingdom
What power do you need? You will have to go for a 12v output after rectification then regulate for all the other voltages but it will have to be accurate output for a PC.
Audio projects and more: gswdh.co.uk
Old 27th April 2012, 07:48 AM   #5
stratus46 is offline stratus46  United States
This discussion took place last fall and it's a poor idea. What is the point of a massively inefficient power supply running a PC motherboard that has switching power supplies on it? You can't get rid of the ones on the motherboard. You'd fare far better with a better analog interface to the motherboard to eliminate ground loops which are FAR more troublesome than switching supplies. If you're using optical or digital outputs rather than analog, it truly is unimportant.
G
Old 27th April 2012, 10:32 AM   #6
Save linear PSU for the few analogue circuits in the PC. That is if they can be separately fed.
regards Andrew T.
Old 27th April 2012, 10:58 AM   #7
it has been don with great succes and its not inefficient coreaudioteknoligi has done so
Old 27th April 2012, 12:00 PM   #8
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I think that's an almost impossible challenge, UNLESS, you use the USB and then supply the USB sound card with a linear regulator.
There is so much digital switching going on that I can see very little benefit though.
IMHO far better just to buy a good quality sound card in the first instance.
Old 27th April 2012, 01:34 PM   #9
barrymagrec is offline barrymagrec
I may be wrong but I don`t think the coreaudiotek is a linear supply, it is a switching supply with additional linear filtering. A complete ATX linear supply would be the size of a desktop PC and be probably less than 50% efficient. A decent quality soundcard is a much better option, or use something like a squeezebox touch.
Old 27th April 2012, 01:45 PM   #10
Core Audio Technology - Home
atx linear power supply newbie helpHide this!Advertise here!
ATX power supply noise. owenhamburg PC Based 9 16th November 2009 10:15 PM
ATX power supply needs a load to run??????? Video Freak Everything Else 2 8th February 2007 11:44 AM
Experiments with an ATX power supply martinab2 Solid State 0 29th March 2004 10:04 AM
Copyright ©1999-2017 diyAudio
