Placid BP 3.1 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd April 2012, 04:56 AM   #1
Can you say Audio?
Default Placid BP 3.1
I'm trying to startup my Placid and I'm adjusting the pots. VR1 & VR2 adjust fine. VR4 does too (~2K) VR3 is ~10.11K. adjusting the pot will bring that up or down, but it's not gonna get there. If I read across R7, I get ~2K resistance - same as reading across R8. Can anyone suggest other checks I can make, or is this likely a bad pot?
Old 22nd April 2012, 11:54 AM   #2
what is a Placid.
schematic or link
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd April 2012, 02:44 PM   #3
Can you say Audio?
Sorry - it's the Twisted Pair Audio OS for Buffalo II. Here's the schematic - thanks for taking the time.
http://www.twistedpearaudio.com/docs..._1_2_schem.pdf
Old 22nd April 2012, 03:32 PM   #4
QP1 is a CCS. Vr2 sets the CCS current.
PIN2 reads the resistor divider. check that voltage.
PIN3 reads the C12 voltage. check that voltage.
IC1 sets the output to QP2 to try to make the voltage difference between PIN2 and PIN3 near zero volts, to within a few tenths of a mVdc, maybe even less if it's a good opamp.
regards Andrew T.
FS: Placid BP v.2.1.2 dsolodov Swap Meet 5 21st June 2016 09:06 PM
placid bp vs bp HD? yammy1688 Twisted Pear 3 3rd September 2011 05:11 PM
Powering LCBPS and Placid BP with one 15V Transformer tubeme Twisted Pear 2 9th August 2011 08:56 AM
PSU Problem with Placid BP and BII tubeing Twisted Pear 5 18th June 2011 03:32 PM
FS: Buffalo II DAC + Placid Combo, Legato I/V Stage, 2x Placid BP Modules damohpi Swap Meet 4 23rd November 2010 09:51 AM
Copyright 1999-2017 diyAudio
