Am I loosing power somewhere?
Old 21st April 2012, 10:20 PM   #1
scutterflux is offline scutterflux  Canada
Default Am I loosing power somewhere?
Hello,
So, I've been trying to bias the left and right sides of my 805 SET tube amp. I can't quite get it right. One side is showing about a 10% difference which I can trace back to the power supply and/or/hoperfully the filtering.
The 390V tap is putting out aprox 360-370V and that makes aprox 860-870V on the B+ which ought to be 950V It's about 10% shy.
What is the likely cause?
Judging by the schematic Is there anything I could do?
Am I being too fussy???
Old 22nd April 2012, 10:49 AM   #2
R.I.P.
What is the voltage drop across 200r?
That will tell you the current that is flowing and will also tell you the voltage at the rectifier output.
regards Andrew T.
Old 22nd April 2012, 11:42 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Is B+ 2 OK ?
Old 22nd April 2012, 08:57 PM   #4
42 volt drop across the resistor, on both sides! However the one on the good side is on 998V and the low side is 937V
B+ 2 is also running a little low. When I set the grid bias even on both sides the voltage on the plates is lower on the low side by 25-35V or so.
Old 23rd April 2012, 08:58 AM   #5
R.I.P.
42Vdrop !
That's almost 9W and 210mA
regards Andrew T.
Old 23rd April 2012, 09:02 AM   #6
If safe to do so, can you run PSU on its own with nothing attached to see if the doubler has a problem.
CHECK that diodes and caps are rated sufficiently high enough for NO LOAD operation.
Old 23rd April 2012, 09:09 AM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by scutterflux View Post
Hello,
yes, i believe you are being fussy....
with a 390Vac transformer secondary, your unloaded voltage should be right around 1092 volts....now as you load your power supply, this voltage drops owing to the secondary dc resistance of your 390volt winding and the 200 ohm resistor in your psu.....
the thing you need to do is set the grid bias voltage to maximum negative...then when filaments are fully aglow, you can then set you bias voltage to get your plate currents to desired value.... you will notice that B+ starts going down with plate current....
if you can post the schematics of your 805, we can look further....
your B+ going lower than desired means that the traffo that you got is a tad lower than what you need, your primary voltage can also be lower so that secondary voltages are likewise lower.........with voltage doublers, what i do is to put several taps on the traffo secondary so i can adjust voltages.....
with tubes, voltage drops on the psu to 100 volts is nothing unusual.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd April 2012, 09:19 AM   #8
TonyTecson's Avatar
i notice there is something wrong with your grid bias circuit....as drawn....
Old 23rd April 2012, 12:18 PM   #9
SjoerdSmits is offline SjoerdSmits  Netherlands
SjoerdSmits's Avatar
Have you checked correct function of your diodes? Had the same problem once, turned out to diodes were out of spec....
Old 23rd April 2012, 01:05 PM   #10
TonyTecson's Avatar
imho....nothing to lose sleep about....
are those plate voltages? the important thing is to get your plate current right....
they must be plate voltages....one having 937volts is drawing more current than the one with 998....
Am I loosing power somewhere?Hide this!Advertise here!
My Solderpump loosing suction? evianamp2011 Equipment & Tools 17 21st June 2011 01:56 AM
KT66 loosing its getter ixe13 Tubes / Valves 2 27th February 2008 01:33 AM
Loosing my BASS somewhere! NickUK Car Audio 3 3rd January 2007 01:29 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
