Disk capacitor replacement/upgrade
Old 20th April 2012, 09:32 PM   #1
Nounours18200 is offline Nounours18200  France
Default Disk capacitor replacement/upgrade
Hi friends,
I work on the upgrade of the power supply card ; the device is a Digital to Analog Converter, with a tube output stage.
On the P.S. card, there is a Disk Capacitor, value = 4,700 pF 1,000V for filtering the voltage.
I would like to know a better alternative than a disk capacitor, as many of us tell that these disk capacitor have a poor quality...
What you would recommend ?
thanks !
Old 30th April 2012, 03:08 PM   #2
Nemuikuma is offline Nemuikuma  Hungary
Why would you want to replace it?
The can introduce distortion into the audio path, but it is in a power supply so it doesn't matter.
They can be temperature sensitive but in this application it does not matter.
The are great to bypass radio frequencies to ground ,that is all they do in this case i think, no need to replace IMHO.
Old 30th April 2012, 05:09 PM   #3
DF96 is offline DF96  England
Ceramic disc capacitors work very well when used for the right reason in the right place.
Old 30th April 2012, 05:34 PM   #4
jcx is offline jcx  United States
Default not all ceramics are alike, not all circuit components are "in the signal path"
if It is NP0 or C0G type ceramic then it is good enough for direct audio signal path use - better than some films and mica
Old 1st May 2012, 01:07 AM   #5
bobrown14 is offline bobrown14  United States
Originally Posted by Nounours18200 View Post
Hi friends,
thanks !
If the cap is connected across the line and neutral coming from the wall outlet (C1) you can put in an MKT-X2 poly cap there in place of the disc cap. It's there to filter RF and spikes on the AC line. It wont affect the sound in any way other than filtering out RF, more for peace of mind. Spikes in line voltage are not good. I had a short in a rectifier tube the other day - took out my PT, ouch. Could have been an AC spike, all I had in there was a bleeder resistor (to keep me alive - go figure). Disc caps are old school version and have been working fine for a LONG time. Just check and see where the one leg of the disc cap is connected to. If it's connected from line to ground you can sub in a Y capacitor, line to neutral go for an X2 cap.
Bob
Disk capacitor replacement/upgradeHide this!Advertise here!
Leach Capacitor Upgrade Toltec Solid State 5 28th September 2011 08:28 AM
X-Over capacitor upgrade UV101 Multi-Way 7 1st May 2009 01:43 PM
CD disk capacitor ? ash_dac Parts 2 30th June 2006 11:14 PM
Capacitor upgrade calvinhpk Parts 6 2nd November 2005 07:57 AM
