I have a flyback converter with the following properties:
- input 230V off line
- output +15V (0.6A) / -12V (0.3A) / +200V (0.05A)
- actual power approx. 25W
- power capacity appr. 75W
Now I need an additional 200V (0.05A) output in the same box.
The catch:
it`s got to be completely isolated from the other HV output.
The question is:
- can I connect a second flyback xfmr in parallel to the existing xfmr`s primary ?
- there should be enough headroom concerning rectifier, switching Mosfet, prim.cap., etc
- regulation of the 2nd HV output necessary ? simple shunt reg. or none at all ? since load is pretty constant and not critical.
- any unpleasant surprises to be expected ?
The catch:
The question is:
current mode
no way to add additional winding
just looking for a quick add-on solution w/o building a new xfmr
tried it anyway - no serious things happened other than the other secondary voltages dropped somewhat and the additional voltage didn't go over 90V which is only half of what I need.
I think that could have been expected ...
