Choke formula - Marty Brown
Old 17th April 2012, 09:56 AM   #1
Archimedes is offline Archimedes  South Africa
Archimedes's Avatar
Default Choke formula - Marty Brown
Hi All
I am presently building a 12V to 330V converter and I have been using a book titled Power Supply Cookbook by Marty Brown as a guide. There is a formula that appears within for calculating the output choke value that I am having a tough time grasping as it seems the result is rather big for such a small smps.
The smps operates in push-pull config at 50kHz and is rated for 120mA max. Vin(min) = 11V
Vin(max) = 15V
Can someone please have a look at my calc. and advise if I misunderstood what was required?
Thank you
Ashraf
Old 17th April 2012, 01:55 PM   #2
Archimedes's Avatar
Anybody??
Old 17th April 2012, 02:09 PM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The inductor at the output only smoots the voltage, and operates as a low pass filter with the out cap. Assuming a delta I, the choke is easy to calculate. Normally it is assumed as a 10% of I load. I also have this book, but it is a bit confusious the math he use. Read any inductor calculation for buck converter type, in fact the inductor operates in the same way as it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 17th April 2012, 02:39 PM   #4
Archimedes's Avatar
Osvaldo, are you saying that calculating chokes for buck converters are exactly the same as calculating an output choke for a forward converter?
Old 17th April 2012, 02:50 PM   #5
Yes!!!
http://www.ti.com/lit/ml/slup127/slup127.pdf
I hope this be usefully.
Old 17th April 2012, 05:02 PM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
Anybody??
The formula is dimensionally correct.
The only point open to debate is the 1.4 factor, it represents the level of ripple you tolerate for the current in the choke, but even if you choose a different trade off, the value will remain in the same range.
It is a normal value for a high voltage converter: the inductance value increase as the voltage squared.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 18th April 2012, 12:31 AM   #7
lizhi3amorphous is offline lizhi3amorphous  China
Banned
can you use the common magnetic chokes or distance magnetic chokes for short the wave?
i think we can solve your question
regards
Jay
Old 18th April 2012, 10:58 PM   #8
Archimedes's Avatar
Thanks for your responses.
Osvaldo, I read the TI note and I can't seem to find where it explains how the inductance of the choke was calculated. The inductance value of the choke was provided all that the note said was what type of core, winding etc.
Elvee, I came across a somewhat differennt formula for calulating the choke from Col. T. McLyman and when I did the calculation I come up with a value of 74.5mH. Now I am more confused as to which value is the correct one.
Jay, I don't understand your question. Please will you rephrase.
Old 19th April 2012, 08:59 AM   #9
Elvee's Avatar
Can you post your schematic, it will make the discussion easier.
Old 19th April 2012, 12:02 PM   #10
Archimedes's Avatar
Here is the schematic.
Choke formula - Marty BrownHide this!Advertise here!
26H choke good enough for a grid or anode choke? speakerfritz Tubes / Valves 7 2nd December 2011 06:05 PM
Help replacing a PSU choke - How to choose choke Hubba Tubes / Valves 2 10th September 2010 02:33 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 08:30 PM
