What does 25+25V mean?
Old 16th April 2012, 08:01 PM   #1
mossen is offline mossen
Default What does 25+25V mean?
On this transformer page
Transformers and Power Converters From Avel Lindberg, Inc.
the secondary voltage is listed as something like 25+25. What does that mean? I want something that gives me +25, 0, -25V. Will this do it?
mossen
Old 16th April 2012, 08:05 PM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
Two separate secondary windings of 25VAC each. You can use one or two rectifiers to make a bipolar supply out of this, so yes, it will suit you.
However, if you're wanting a supply that provides +/- 25VDC, you'll want to choose a transformer with lower voltage secondaries than 25VAC.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 16th April 2012, 08:15 PM   #3
preiter is offline preiter  United States
preiter's Avatar
To expand upon that answer. When you rectify a 25VAC input, you will end up with a 25 * sqrt(2) VDC output, which is about 35V.
For a 25VDC output, you are going to want closer to a 18+18 VAC transformer.
Whether your DC outputs are positive or negative depends on how you wire the power supply. The transformer is the same either way.
Old 17th April 2012, 03:45 AM   #4
nazaroo is offline nazaroo  Canada
Banned
You should also factor in a few extra volts on each rail if you want a REGULATED supply, because regulators need the extra volts to properly work.
The basic design would look like this:
The 2200 uF here seems high (typical examples from regulator makers suggest .22 at input and .1 uF at output of chip).
Anyway, the top is a 7800 series (7812 = 12v +, 7809 = 9v +)
and the bottom should be a 7900 series (7912 = 12v -ve etc.)
The raw rectified DC in should be at least 2 volts higher than the regulated DC out you want, so a 12 volt plus and minus means about 15-20 volts going in.
Here's an example +- 15 volt supply:
You need to get about 18 v from (c.t.) Ground on each input UNDER LOAD.
use Ohm's law to figure out what your load is.
If you know you need a 100 mA supply on each rail,
then your load will be Ohms = Volts / Amps = 15v / .1 = 150 ohm load.
Then calculate watts:
Watts = Volts X Amps = 15 x .1 = 1.5 watts.
Now hook up a 2 watt or larger 150 ohm resistor to the raw supply, and measure the D.C. voltage, under that load.
This will tell you what the transformer can put out at that current draw (do both sides like this at once, to load both sides of your supply to ground.
In the above picture you'd hook up a resistor to both plus and minus supplies, and see what the voltage across each was.
For example, I needed a 9 volt supply (single sided) for my guitar pedal. I ended up using a 12 volt A.C. transformer, which actually delivered much more without a load. I ignored those voltages and hooked it up to a rectifier bridge, added a PS cap, and then put a 1 Amp load on it. I found it put out indeed about 13 volts D.C. under load, which was fine, so I added a 7909 regulator with a heatsink and some small caps, and got a pedal powersupply that delivered almost exactly 9 volts, and could power about 10 pedals at the same time, of various current draws.
Old 17th April 2012, 12:42 PM   #5
Have you spotted the "message" yet?
You must avoid ambiguity between DC and AC and average and peak and peak to peak.
You must specify the units unambiguously.
If the +25Vdc, 0Vdc, -25Vdc had been seen you would not have to ask the question.
Similarly +-25Vdc is quite different from 25,0,25Vac
regards Andrew T.
Old 20th April 2012, 07:40 AM   #6
Banned
Its a common standard to describe center-tap transformers as "300-0-300" or alternately as "600v c.t.", in each case meaning the same thing:
300 AC RMS from c.t. to either endpoint and/or 600 v AC RMS from the extreme ends of the secondary winding.
Sometimes this winding is really two 300 v.a.c. rms simply wired in series with a 3rd wire as the c.t., joined to the point where the two coils are connected internally.
It could never mean anything else, such as "D.C." or "Peak/p2p" and the RMS (root mean square) is because of convention, as it conveniently expresses the same amount of power that a D.C. voltage would, and so 10 volts RMS A.C. = 10 volts D.C..
Toroidal transformers always put out A.C. only (only a complete powersupply design could specify a D.C. voltage).
So for a transformer "25 + 25" means two output windings (not connected to each other) each which puts out 25 v A.C. RMS. hooking them end to end in proper phase would give 50 volts RMS A.C.
This A.C. (25 - 0 - 25 series c.t.) could produce either a 25 volt or a 50 volt supply depending upon how it is rectified and filtered. The actual D.C. voltage on the load would vary according to load and/or further regulating components.
In the case of a transformer, the "+" sign doesn't mean polarity or that a D.C. voltage is being measured.
Instead it simply means "and", that is "25 + 25" means 25 AND 25, that is two 25 volt windings (AC).
Old 20th April 2012, 03:17 PM   #7
Nar,
if you want to be ambiguous just carry om omitting AC or DC from your stated units of measurement.
If you want to help beginners avoid being confused, then I strongly suggest you change your opinion in how to state voltages.
regards Andrew T.
Old 20th April 2012, 07:22 PM   #8
Banned
Nar,
You're right of course Andrew.
I was merely trying to explain the practice of how the transformer seller
chose to list his transformers. (see OP)
Really the seller could have done better here,
but the convention used is very common.
Old 21st April 2012, 12:07 AM   #9
Default One more question
Thanks for all the answers, everyone, it is making sense. About the power rating of the transformer: if it is listed as 160VA, how is that interpreted?
For example, if the transformer provides 18+18V, does this mean the transformer can deliver:
160VA / 36V = 4.44 amps?
or is the rating per secondary:
160VA / 18V = 8.88 amps?
or do I completely have the wrong idea here?
mossen
Old 21st April 2012, 06:11 AM   #10
Banned
mossen
I think the rated VA of a transformer is the total power drawn through it, when all secondaries (outputs) are loaded at their ratings.
Thus the total wattage (VA) is the MAINS current x MAINS voltage.
It might be possible (within sensible tolerances) to draw some more current through one winding,
while leaving another unused, keeping the total power within the VA specs.
Wire in the coils is rated by amperage only,
while insulation is rated by voltage.
A small increase in amperage may be well within specs, provided there is no heat buildup or breakdown of HV insulation, or any possibility of transient HV spikes (these are the typical cause of insulation breakdown.)
What does 25+25V mean?Hide this!Advertise here!
Shanling Cd-S100/ Music Hall 25 (25.2) fluorescent display source? limono Parts 2 5th August 2011 02:22 AM
500VA 30+30V and 225VA 25+25V toroidal transformers FS chris-man Swap Meet 26 14th May 2009 01:12 PM
FS Avel Lindberg 250VA 25V+25V Toroidal Transformer chevy2410 Swap Meet 10 1st March 2009 07:14 AM
cheap (230v 50hz) 160va 25+25 tranny on ebay guitar_joe Swap Meet 0 24th November 2007 11:53 PM
UK: 2 x Encapsulated Toroids 25-0-25v 160VA ShinOBIWAN Swap Meet 6 14th February 2006 10:56 AM
Copyright ©1999-2017 diyAudio
