CT transformer Amperage Question - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th April 2012, 12:59 PM   #31
AndrewT is online now AndrewT  Scotland
I did in post4.
We now have three of those questions answered and just three more to go.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th April 2012, 01:00 PM   #32
KatieandDad's Avatar
I've applied a good practical test and included the relevant safety warnings.
No guess work - just a simple test that the average guy can carry out.
Old 15th April 2012, 12:14 AM   #33
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by KatieandDad
it is the thickness of the secondary winding that really determines the (max) output current.
it is the thickness of the primary winding that determines the maximum input current.
Both limiting values must not be exceeded for continuous operation.
both primary and secondary resistance have an effect...but the thing that limits how much power can be drawn out from secondary terminals is temperature and insulation qualities of the traffo, how hot are you willing to go? how high will the temperature be before insulation of wires and bobbins start to burn out or melt?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th April 2012, 12:24 AM   #34
AJT's Avatar
Originally Posted by MrAdel1984 View Post
Hi guys
Sorry for late response and thanks for help
The trafo is -thank god- still alive and it's an E-I ,secondary wire diameter is about 0.5 mm, primary (couldn't see it)
Any Way , Trafo manufacturers in my country don't give a damn about amperage
0.5mm is american ga#24, i would normally use that wire for 0.5 to 0.8 amps in my traffos....gainclones have huge psrr's that the dc resistance of your traffo hardly matters....
so the 4amp spec quoted to you is a joke.....
if you want to use it for a gain clone, you can, the voltage will sag big anyway...your unloaded rails will be +/-40 volts......
for an lm3886:
Supply Voltage |V+|+|V−|
(No Signal) 94V
(Input Signal) 84V
Old 15th April 2012, 09:57 AM   #35
godfrey is offline godfrey  South Africa
Sheesh, are you guys still arguing about this?
Normal people could've built the amp finished by now.
Linear PS CT transformer question empaist Power Supplies 6 14th January 2012 04:16 PM
Power transformer amperage slideman82 Power Supplies 7 1st May 2010 06:54 AM
Question about CT transformer and Brian's Rev C power supply board maurycy Chip Amps 9 8th December 2009 09:21 AM
transformer with ct or non ct? galih Chip Amps 7 7th December 2009 05:08 PM
Using a transformer without CT? Serow Pass Labs 3 19th November 2003 09:50 PM
Copyright 1999-2017 diyAudio
