#11 |
No.
#12 |
Of course it will.
If a transformer is rated at 4A then you can load it to 4A and make sure that it is running and not getting too hot. You can also expect the voltage to be within approximately 90% of its no load voltage. If you need more precise regulation figures you are going to need its datasheet. |
#13 |
Still no.
I accept and recommend that a LOAD TEST is the best way to determine the VA rating of the unknown transformer. But you must have the equipment and knowledge to allow the test to be carried out in a meaningful way. Otherwise the results will be worthless. Worse, one incompetent Member is quite likely to damage a perfectly good transformer due to lack of resources. |
#14 | |
Hopefully the guy will have some common sense and apply the load gradually. Maybe 0.5A at a time until the voltage starts to drop. |
#15 |
I never argued with your statement that a LOAD TEST is good.
What I abhor is your completely useless method, that you are recommending to an incompetent Member. |
#16 |
It works.
#17 |
I refer you back to post9.
Now try to compare post4 and post5 and try to convince us that your method is safer than mine. |
#18 | |
drawing 1 ampere out from your secondaries drops 3 volts per side, so that your 28-0-28 traffo becomes a 25-0-25 traffo..... drawing 2 amps, your traffo secondary drops some more so that it now becomes a 22-0-22 traffo.... more current drawn means lower voltages.....this is called regulation...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#19 |
I'm not going to get into an argument.
It is ONE WAY of identifying the VA rating of a secondary. If you have other ways then voice them and help this guy out. Weighing it doesn't help much unless you know 1) The material and 2) The flux density used by that manufacturer. |
#20 |
a 28 0 28v / 4 A traffo means that the terminal voltages are 28-0-28 when a load resistor drawing 4 amperes are connected to its terminals...
having said this, the open circuit of your traffo must be higher than 28-0-28 to meet the 4amp load spec....
| Linear PS CT transformer question | empaist | Power Supplies | 6 | 14th January 2012 04:16 PM |
| Power transformer amperage | slideman82 | Power Supplies | 7 | 1st May 2010 06:54 AM |
| Question about CT transformer and Brian's Rev C power supply board | maurycy | Chip Amps | 9 | 8th December 2009 09:21 AM |
| transformer with ct or non ct? | galih | Chip Amps | 7 | 7th December 2009 05:08 PM |
| Using a transformer without CT? | Serow | Pass Labs | 3 | 19th November 2003 09:50 PM |
