Hi all!
Ive been researching and designing a pretty straight forward halfbrigde smps lately, i would like your inputs on it. Mainboard: ![]() ![]() Driver board: ![]() ![]() What do you think? Im a little unsure about PCB layout, and unsure about both primary and secondary side filter.. Output should be about 80V and 30A. Audio usage. Ive built a prototype with somewhat different PCB layout but i had huge problems with noise, but it did push out 2.8kw / 39A @ 74V at 75khz for a couple minutes before core got to hot. Final type is supposed to be at 100khz Soft-start board and current sensor-board is still to be designed. Any suggestions for optimization? Thanks |
#2 |
Banned
hi i dont see fan....you need fan for that power level.
i dont see pfc stage.....with that power you cannot realistically do it without pfc.....a simple rectifier bridge and cap bank input would pull too high current peaks. |
#3 | |
Fan controller is placed externally.. Ive seen many design with this amount of current without PFC...? |
| Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted | tiefbassuebertr | Analogue Source | 30 | 21st October 2012 07:01 PM |
| Suggestions? | billbeau | Chip Amps | 5 | 29th October 2008 03:49 PM |
| Give some suggestions for a SMPS newb? | eVITAERC | Power Supplies | 3 | 6th December 2005 09:46 AM |
| Suggestions please.. | satelitis | Tubes / Valves | 1 | 25th April 2004 11:59 AM |
| Any suggestions | Diode | Multi-Way | 2 | 7th December 2003 03:49 AM |
| Page generated in 0.23471 seconds (100.00% PHP - 0% MySQL) with 9 queries |
