Help! Battery charger +/- 41,2V with TL783
Old 25th August 2012, 11:01 PM   #11
tauro0221 is offline tauro0221  United States
Check the voltage at pin3 of the voltage regulator This is to check if you have enough voltage to regulate it.
Old 25th August 2012, 11:16 PM   #12
Why you need the current regulator? I will remove it. At the beginning when the battery voltage it is lower than the 41.2 the current will be high but as the battery voltage increase the current will decrease, When the voltage are the same it will have a small current going to the battery. It will adjust itself.
Old 27th August 2012, 07:18 PM   #13
McLanz is offline McLanz  Germany
McLanz's Avatar
Hi Tauro,
Thanks for your suggestions again! I will check pin 3 ...proably its already my problem.
For the current reg: The batteries should get a tenth of their capacitance = 7.2Ah means charging with max 0.7A. That is my logic here. But somehow you are right my toroid can draw 3.5A max means 1.75A per rail. The Batteries won't discharge that much anyway as they a usual listening session isn't able to discharge them significantly.
Good idea to simplify the circuit
Did you ever built a negative TL783 circuit? I'm really wondering about the Rset=42KOhms
Jochen
Old 27th August 2012, 07:34 PM   #14
I used it a lot for pos/neg power supplies but I used the 82 ohm for the R1 and used the equation to calculate R2. Another suggestion it is to let the battery discharge and then charge it while monitoring the current to see where the battery current stop. Then raise the voltage a little to maintain a trickle charge.
Help! Battery charger +/- 41,2V with TL783Hide this!Advertise here!
Car battery charger atash_tah Power Supplies 2 13th February 2010 10:09 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
R/C battery and charger jaudio Power Supplies 3 18th February 2009 07:27 PM
Battery Charger ThSpeakerDude88 Everything Else 13 6th September 2006 10:40 PM
