connecting primaries in series
Old 8th May 2012, 05:10 PM   #31
Lazybutt is offline Lazybutt  France
Originally Posted by kevinkr View Post
What KatieandDad says!
Check out this inexpensive Antek: Antek - AN-3218 Even with shipping it should not be too bad.
Yeah not bad...... hee hee
But I could have had 2 sealed Avel-Lindberg for even cheaper than that.... so I was tempted.
I didn't see the issue when used in perfectly parallel channels in CLass A, but I guess the argument about caps tolerence has finished convincing me
Old 8th May 2012, 05:11 PM   #32
AudioSan is offline AudioSan  Norway
Originally Posted by KatieandDad View Post
Not quite. The transformers will still be at rated power but the drawn power will be as you suggest.
no it will not. the amp rating remains the same.
but voltage is only half. so you loose 50% VA rating.
Old 8th May 2012, 05:16 PM   #33
True. And this is because the amp rating is driven by wire gauge.
You still get the same "rating" for the core though... so it's like an oversized core....
Old 8th May 2012, 05:17 PM   #34
exatly
connecting primaries in seriesHide this!Advertise here!
Help: Connecting two Fluke meters in series HP8903B Equipment & Tools 19 29th January 2012 01:58 AM
connecting heatsinks in series reddish75 Solid State 10 13th July 2010 08:15 AM
Shorten leads of primaries to connect them in series ? coolnose Power Supplies 3 7th April 2010 02:48 PM
Series connecting output Transformers. Shoog Tubes / Valves 55 12th February 2007 05:22 PM
help connecting primaries Raj1 Parts 12 23rd September 2003 04:59 PM
