Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th May 2012, 03:24 PM   #21
Originally Posted by KatieandDad View Post
WOOOAAA.
You would be better to sell on the different transformers and buy the correct one in the first instance.
You're probably right....
but these toroids are second hand, and I don't think I could find such high quality as such low price so easily.
I especially liked the fact that they are sealed, which is rare and that I was like for low hum....
Nevermind... I found another pair of quality toroids :P (but a bit more expensive and not sealed... )
Thanks!
Old 8th May 2012, 03:30 PM   #22
DF96 is offline DF96  England
You can only connect transformer primaries in series when the secondaries have identical loads, or are tightly coupled together (usually by being wound on the same core!). Identical loads is almost impossible to achieve: you need not just identical circuits taking identical currents, but also identical smoothing caps (note that big electrolytics usually have very loose tolerances). This balance needs to be maintained under all conceivable fault conditions.
Paralleling secondaries should only be attempted when they are on the same transformer or with ballast resistors to aid current sharing.
The quick answer, as others have said, is don't do it!
Old 8th May 2012, 04:14 PM   #23
Thanks!
and if it works okei. the transformers will be 337VA/2 pr pc.
so 168.5VA pr transformer
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 8th May 2012, 04:17 PM   #24
KatieandDad's Avatar
Not quite. The transformers will still be at rated power but the drawn power will be as you suggest.
Old 8th May 2012, 04:22 PM   #25
elic is offline elic  Israel
When four 200 VA transformers cost you around $10, you don't ask too many questions :-)
Old 8th May 2012, 04:51 PM   #26
The transformers each have 2off 115Vac primaries. These can be wired for either 110/120Vac, or for 220/240Vac. You don't have to mix up windings on different transformers.
Old 8th May 2012, 04:52 PM   #27
He's trying to reduce the secondary output.
Old 8th May 2012, 04:56 PM   #28
one does not mix up windings on different transformers.
There are better ways to reduce the output voltage than mixing up primary windings.
I have described the method previously and I can confirm that method does not lose any VA rating of the secondaries. But the description does have a warning. It is not for beginners who cannot recognise the dangers inherent in mucking about with mains transformers !!!!!!!!!!!!
Old 8th May 2012, 04:56 PM   #29
kevinkr's Avatar
Theoretically it seems OK. However, my experience of connecting transformers in series has always been poor results.
What KatieandDad says!
Check out this inexpensive Antek: Antek - AN-3218 Even with shipping it should not be too bad.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 8th May 2012, 04:58 PM   #30
You will always be better off with the correct transformer.
Help: Connecting two Fluke meters in series HP8903B Tubes / Valves 19 29th January 2012 01:58 AM
connecting heatsinks in series reddish75 Solid State 10 13th July 2010 08:15 AM
Shorten leads of primaries to connect them in series ? coolnose Power Supplies 3 7th April 2010 02:48 PM
Series connecting output Transformers. Shoog Tubes / Valves 55 12th February 2007 05:22 PM
help connecting primaries Raj1 Parts 12 23rd September 2003 04:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
