connecting primaries in series
Old 9th April 2012, 09:55 AM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by elic View Post
Each one has a single secondary.
in that case you can connect primaries in series ;
will explain later , have some things to do
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th April 2012, 10:16 AM   #12
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
ANY imbalance will become expensive when they become apparent. A few Euros saved at this point may cost hundreds of Euros in the future.
Have a look on E-Bay and at http://www.rs-online.com There are loads of 625VA transformers for about 60.
http://www.amazon.co.uk/MULTICOMP-Tr...3966730&sr=8-3
Old 9th April 2012, 10:18 AM   #13
elic is offline elic  Israel
This is a good argument, I agree. I thought a fuse will save me in this case. but I guess I should get a suitable transformer.
Old 9th April 2012, 10:22 AM   #14
In a Class A/B amplifier only one half is drawing the maximum current at one time - IMBALANCE.
Old 9th April 2012, 10:30 AM   #15
SoNic_real_one is offline SoNic_real_one  United States
Agree, this is a bad idea. If the secondary coils where in paralel, I could see it as an option, but as separate loads, charging the smooting capacitors alternatelly (like it was already said due to class A/B)... It will end up in smoke.
Old 9th April 2012, 06:21 PM   #16
Thank you all. I give up :-)
Old 8th May 2012, 02:10 PM   #17
Lazybutt is offline Lazybutt  France
Hello Guys,
Incidentally I had the same question, but for a Class A amp (FirstWatt F2J):
I found 2 very nice Avel Lindberg 337W sealed toroids second hand (and cheap!)
Primary: 2 x 115V
Secondary: 2 x 37V
Mains is 230V where I live and I was thinking of putting each primaries (totally 4 windings) in series to get 4 secondaries at 18.5 VAC (that I would parallel 2+2 to get 2 channels).
Is this any better idea in Class A than class AB ?
And also, do I somehow lose the reduced crosstalk benefit of having 2 seperate toroids by doing so ?
Thanks a lot !
Old 8th May 2012, 02:32 PM   #18
as long as you connect the secondaries of different transformers in series you should be OK. In fact, I am going to do the same but with four different 110V transformers. I will connect each two's primaries in series and connect secondaries in series (that's because I have only one secondary in each transformer).
Old 8th May 2012, 03:00 PM   #19
WOOOAAA.
Be VERY VERY careful.
If you keep everything IN PHASE then you should be OK.
Funny things do happen with transformers in series though. You would be better to sell on the different transformers and buy the correct one in the first instance.
Old 8th May 2012, 03:01 PM   #20
Originally Posted by Lazybutt View Post
Hello Guys,
Primary: 2 x 115V
Secondary: 2 x 37V
Thanks a lot !
Theoretically it seems OK. However, my experience of connecting transformers in series has always been poor results.
connecting primaries in seriesHide this!Advertise here!
Help: Connecting two Fluke meters in series HP8903B Equipment & Tools 19 29th January 2012 01:58 AM
connecting heatsinks in series reddish75 Solid State 10 13th July 2010 08:15 AM
Shorten leads of primaries to connect them in series ? coolnose Power Supplies 3 7th April 2010 02:48 PM
Series connecting output Transformers. Shoog Tubes / Valves 55 12th February 2007 05:22 PM
help connecting primaries Raj1 Parts 12 23rd September 2003 04:59 PM
