Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th April 2012, 07:11 PM   #1
akis is offline akis  United Kingdom
Default Electric fields
Hello
Did not know where else to post this question - how do I translate the strength of an electric field say across the plates of a capacitor from say 1V/cm to something more common, eg Volts?
Akis
Old 5th April 2012, 07:21 PM   #2
Lukas87 is offline Lukas87  Czech Republic
Just multiply the E (in V/m) by the distance (in m, of course) between the plates.
Old 5th April 2012, 07:28 PM   #3
DF96 is offline DF96  England
The strength of an electric field is V/m (volts per metre). If you want something more common that that I suppose you could convert it to volts per foot or volts per inch.
Old 5th April 2012, 08:30 PM   #4
I figured as much. So 1V/cm across say 15cm is really 15 Volts.
Old 5th April 2012, 08:36 PM   #5
No. 1V/cm is the strength of the electric field. If this field strength is maintained over a distance of 15cm then you will get a potential difference of 15V. Two different measurements of two different things: electric field and potential.
Its like the difference between the height of a hill and the slope. Both tell you something about the hill, but they tell you different things so are measured in different units.
Old 5th April 2012, 08:42 PM   #6
Originally Posted by akis View Post
Hello
Akis
You don't, an electric field is an electric field, if you want to know volts you need to measure volts.
Yes, though most practical applications are more likely to be measured in v/um
Old 6th April 2012, 01:15 PM   #7
Dear Akis - look on the problem in a way that the E is like the slope of the hill and the V is like the height. It will be all much easier to understand.
Visualization of magnetic fields planet10 Everything Else 2 25th September 2011 09:25 PM
enclosing magnetic fields johnferrier Construction Tips 7 18th April 2011 06:25 PM
do mosfets suffer from magnetic fields pointy Solid State 2 7th March 2010 03:31 PM
Tubes and magnetic fields SY Tubes / Valves 35 11th January 2005 07:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
