I am planning to build power conditioner/isolator for my tv and audio equipment. Depending on costs, I amplanning to build the following
1.) AC mains -> caps -> CMC -> caps -> component 2.) AC mains -> Trans 1 primaries/Trans 1 secondaries -> caps -> trans 2 secondaries/ trans 2 primaries -> component. (where trans 1 and trans 2 identical step down trannies) How do I calculate the values for the trannies and CMC? I am in the US (110 v) and the biggest device would be the TV that sucks 628 watts. Now I know ohm’s law, but how trannies are rated is just way above my pay grade. Also, how do I calculate the fuse sizes? Thanks for any help. Apuesto |
#2 |
For reasons of safety, I recommend you copy an existing design exactly. Even better, buy one. Otherwise, check that your loved ones have adequate insurance on your life and your house. Sorry, but if arithmetic confuses you then you really should not be building power conditioners.
#3 |
LOL! Good advice I am sure DF.
I'm comfortable with the design and have built one for a phono amp with good result (and no fires yet!). I cannot find the formula (or probably do not recognise it if I did see it) that will tell me what rating a transformer or choke should be to be able to supply a component drwaing a specific wattage. |
| Mathematically challenged help for lm 317-337 | semi932 | Power Supplies | 18 | 5th January 2011 10:16 AM |
| Wanted cosmetically challenged DCX2496 | Zero Cool | Swap Meet | 0 | 27th October 2010 11:07 PM |
| Customizing manufactured speakers to fit a height challenged AV theatre setup. | morkyz | Multi-Way | 8 | 12th January 2009 04:09 AM |
| Help please for opamp challenged.......... | rabbitz | Solid State | 3 | 6th April 2004 02:42 PM |
