Is PSUD II trust-worthy or not?
Old 7th April 2012, 10:13 AM   #21
R.I.P.
integer possibly
regards Andrew T.
Old 10th April 2012, 11:30 PM   #22
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Click on stuff. You'll find it.
Old 13th April 2012, 02:17 PM   #23
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
Originally Posted by Loudthud View Post
integral \in-ti-grel\ adj 1 : essential to completeness 2 : formed as a unit with another part 3 : composed of parts that make up a whole 4 : ENTIRE
Which of these meanings did you have in mind? A number essential to completeness? A number formed as a unit with another part? A number composed of parts that make up a whole? An ENTIRE number?
Or the obvious meaning left out by your dictionary, being the result of a mathematical process of integration?
Enough ppl have understandable difficulty with technical English here without unnecessarily complicating matters.
You meant "integer". I won't insult you by posting its dictionary definition.
Ian
Old 14th April 2012, 04:30 PM   #24
max29 is offline max29  Netherlands
Question about the Load the PSUII is asking for.
Can be A (mA) or Ohms (makes big difference).
From each Filter section current flows into the circuit.
Say: I have 15mA current going into the 5 filter sections (the L R and C)
How to calculate the right Load resistance at the end?
The Psu gives mostly a 5K. Where did he get this from . Made up out off ?.
Old 14th April 2012, 06:12 PM   #25
DF96 is offline DF96  England
Ohm's Law will solve your problem. You can test a PSU with either a resistance (so current changes with voltage) or a constant current load (so current stays the same). In many cases results will be similar, but sometimes you will see different LF ringing.
Is PSUD II trust-worthy or not?Hide this!Advertise here!
SimpleSE PSUD II B+ squiffiness Tubelab 19 31st January 2012 02:15 AM
Need help with PSUD II model jrenkin Tubes / Valves 6 14th February 2010 12:12 AM
PSUD II soft start Richard Ellis Tubes / Valves 1 12th November 2009 02:41 AM
Tube tester and PSUD II questions boywonder Equipment & Tools 6 26th August 2008 12:38 AM
PSUD II help Bengali Tubes / Valves 10 15th September 2007 04:58 PM
