Adapting SMPS adapters
Old 13th May 2012, 09:33 AM   #11
hollowman is offline hollowman  United States
hollowman's Avatar
Default Minimizing Switching Regulator Residue in Linear Regulator Outputs
Ferrite beads before/after ...
Just saw this on YouTube -- a topical lecture given by Linear Tech:
Minimizing Switching Regulator Residue in Linear Regulator Outputs - YouTube
or:
Linear Technology Video Channel - Minimizing Switching Regulator Residue in Linear Regulator Outputs
"Linear regulators are commonly employed to post-regulate switching regulator outputs. Benefits include improved stability, accuracy, transient response and lowered output impedance. Ideally, these performance gains would be accompanied by markedly reduced switching regulator generated ripple and spikes. In practice, all linear regulators encounter some difficulty with ripple and spikes, particularly as frequency rises. This video, excerpted from LTC Application Note 101, explains the causes of linear regulatorsí dynamic limitations and presents board level techniques for measuring and improving ripple and spike rejection."
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 13th May 2012, 10:33 AM   #12
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Can't say I noticed a "tired" sound when using an LM317T.
I built a SALAS Shunt Reg in the end.
Mezmerize DCB1 Building Thread Post #501
Old 5th July 2016, 07:04 AM   #13
ginetto61 is offline ginetto61  Italy
Originally Posted by KatieandDad View Post
... Most amps work brilliantly with good CRC or CLC supplies.
My experiments with the Pass B1 showed virtually no improvement between a good CRC supply and a full blown Salas Shunt Reg
This will insite the purists I know. But if you are a purist then you will need a dedicated PSU
Hi and sorry to take up again a very old thread that I found only now
Is there a specific thread describing your experiments with the Pass B1 and the schematic you used for the CRC filter ?
I am trying to keep things as simple as possible because I am not that good at building circuits.
Thanks a lot.
Thank you very much indeed
Kind regards,
gino
Adapting SMPS adaptersHide this!Advertise here!
Adapting Speakers farmerjg Car Audio 18 24th April 2011 08:37 AM
Adapting small drivers to a TL pjblakey Multi-Way 6 14th February 2011 09:37 PM
adapting original passive crossover keyser Multi-Way 0 22nd February 2005 11:49 PM
Adapting a Car Antenna to an F coaxial Verse~Chorus Car Audio 4 13th February 2005 03:57 PM
adapting unreg PSU to Brian's boards Milkduds Chip Amps 11 7th January 2005 10:21 AM
