| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#531 |
Electrons are yellow
Has your design seen the day of light yet?
/Per-Anders (my first name) or P-A as my friends call me BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb, checking interest Sign up HERE Rectifier bridge RFB03 Group Buy Round 2, checking interest Sign up HERE |
#532 | |
Thanks Jack! |
#533 |
No, I got sidetracked with the LME49600 buffer design -- I think that one should be put to bed, fwiw.
I want to do some more work on the PCB, ground plane etc. before I send out the design to be burned.
TinTin -- banned in Brooklyn |
#534 |
Just so y'all know, Old Colony still has the boards from the original article -- I just ordered some more yesterday. Apologies to everyone at ADI --there's an LT115 in there, but I promise to switch it out for an AD825!
#535 |
Here it is installed in a CROWN IC-150A preamplifier -- it's mounted on the rear panel on nylon standoffs -- I have LT1028's in there I think:
![]() The Crown power supply runs to +/- 30VDC which had to be reduced with some resistors - elsewise I would be blowing up caps again -- the preamp itself doesn't draw a lot of current, but the regulator is a tad thirsty for milliamps.
#536 |
Looking good Jack. Remote sensing?
#537 |
Yes, the Jung Regulators with the Old Colony Boards provide for remote sensing.
I will mount some AD825's on Aries adapter boards when I am done.
#538 |
I know; seeing the wire length between the regulator and load I was asking if you used the feature. Don't know anything about your preamp, perhaps it does ok with highish zout from the regulator.
#539 |
When I get my analyzer I will measure the impedance "in situ" -- figure that you've got a strand of #20 awg wire 4" long.
I also received PA's super reg boards yesterday and will run them through their paces. He enables the flexibility to use both the LM329dz or TL431.
#540 |
20 awg solid wire of 4'' would be about 118nH. You'd get quite an increase in output impedance with that without remote sensing.
I'm looking forward to your measurements. Thanks for sharing your adventures! Oh, btw, what analyzer will you use? This is something that I wish I had, for sure. |
| Thread Tools | |
| Page generated in 0.18204999 seconds (64.29% PHP - 35.71% MySQL) with 11 queries |
