#521 |
Hi Aparatus,
PCB layout and component numbering to match a schematic would allow copies to be made.
regards Andrew T. |
#523 | |
The Super Reg is most often used with preamps -- and the load is pretty much constant -- noise is a more important consideration. If you must do transient testing you can take a look at this application note by Jim Williams of Linear Tech: http://www.linear.com/pc/downloadDoc...1,P1754,D17358 |
#524 |
Electrons are yellow and more is better!
It was a good application note. I have never seen it of some peculiar reason.
/Per-Anders (my first name) or P-A as my friends call me |
#525 | |
I'm a bit slow, now I'll get it
#526 | |
#527 |
Bumping again -- I've used another set in another Crown IC-150 preamp
#528 |
I'll guess the tube super regulator is very forgotten and not very popular these days. I think I will redraw Mr. Pease's schematic in order to understand it better.
#529 |
I have made a new super regulator board with a 4-layer pcb. I haven't had the opportunity to test it particularly much but so far it looks good in more than one sense.
![]() ![]() Now the regulator can cope with 50 V in and 36 V out without too much trouble. It's also easier to trim the output voltage. The copper thickness is 140 um for the power traces since they go on both sides which have 70 um copper.
#530 |
Here's a "dually: -- I had some made a while back -- without the LM317/337 pre-regulators. I'm not keen on SMT electrolytics for DIY so will use the same devices from the Audio Amateur article, I have bucket loads of TO-92 LM329DZ as well, but the LED's, Diodes, transistors are all SMT.
| Page generated in 0.10956 seconds (77.49% PHP - 22.51% MySQL) with 11 queries |
