Go Back   Home > Forums > Amplifiers > Power Supplies
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 4th March 2007, 01:18 PM   #491
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by peranders
The PSRR is different at the positive vs. negative supply pin.
Hmmm. Yes. Never thought about that. You may have apoint there.
Jan Didden
/“If controlled, repeated tests come out the same again and again - that's Nature saying you're right"
Meet me at Linear Audio
Old 4th March 2007, 05:24 PM   #492
jackinnj's Avatar
In the "Improved" version with the LM317/337 pre-regulator there's only 2.3 Volts dropped across the Super-Regulator -- this should require a much smaller heat sink than 9 C/W.
Old 7th March 2007, 09:09 PM   #493
janneman's Avatar
Originally posted by jackinnj
I don't have an Audio Precision to make the noise measurements, but hooked up the HP3581A (which has 100 nanovolts lowest scale) to the Super Regulator with the Old Colony boards, zener instead of 1N4148 and an AD825AR on a high quality adapter and AD797AN. There is no pre-regulator for either setup:
Interesting. Any idea why that curve shoots up at 40kHz or thereabouts? Is this a measurement artifact?
Yes, that 797 is pretty good. It's just that it often seems difficult to get it stable in these regs.
Jan Didden
Old 7th March 2007, 10:04 PM   #494
jackinnj's Avatar
Jan Didden
Jan I deleted the picture -- the WJ/JD articles used a constant Q filter which would should show a rising 3dB slope as WJ explained in 2/95 -- the HP3581 is constant bandwidth and I was trying to keep the BW as a % of the CF relatively constant -- the narrowest is 3 Hz -- but this is 30% of the lowest frequency and only 0.006% of 50kHz. In any case, I didn't want to mislead -- I will show the data in the graph below and it is really only useable as a relative assesment since the HP3581 has some nV of noise which can't be eliminated -- I thought there was an artifact as well, but the data is repeatable. Again, the Oreo cookie tin was used to good effect.
Old 7th March 2007, 10:37 PM   #495
Electrons are yellow
peranders's Avatar
Are you able to do some weighted measurements like DIN-A or something?
/Per-Anders (my first name) or P-A as my friends call me
BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb. Not too late to sign up. Sign up HERE
Old 8th March 2007, 12:02 AM   #496
jackinnj's Avatar
P-A -- I want to crank up the calorimetric true RMS meter first -- I just repeated the measurements again with the LT1055, and redid the AD797 -- I will have to look through my opamp box for more single JFET devices to test out.
Old 8th March 2007, 04:58 AM   #497
peranders's Avatar
Do you use LM329 + 1k+ 100 uF as voltage reference?
Old 8th March 2007, 11:23 AM   #498
jackinnj's Avatar
I use LM329DZ + 4.99K + 120uF/25V
Old 8th March 2007, 11:24 AM   #499
peranders's Avatar
Is your LP-filter 5k+100uF ?
Old 8th March 2007, 11:49 AM   #500
jackinnj's Avatar
There are a pair of 1K resistors which determine the error signal fed to the inverting input. The Voltage Reference is driven from the Positive Sense pin -- all of this is on a stock Old Colony board -- the only exception is that the filter capacitor which used to be on the positive supply pin is now across the diode to the collector of the 2N5087, and a zener is used instead of a 1N4148.
With respect to the noise -- I want to remake the calculations using some different equipment -- I have two filter setups which are not part of the graphs -- a 100 milliHz to 10 Hz filter which TI uses when characterizing the TL431, an a 10Hz to 100kHz filter which Linear used in Application Note 83"Performance Verification of LDO Regulators". I use these with the HP3403 true RMS meter which uses a thermopile, not a log-antilog RMS detector.
Thread Tools
Page generated in 0.10721493 seconds (75.22% PHP - 24.78% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
