#471 |
#472 |
Electrons are yellow and more is better!
Can't see but have you an emitter follower down to ground from the opamp output? The zener arrangement should create 7-9 volts at the output in order to give supply voltage to the opamp. Have you as a test tried to feed the opamp from the unstablized side (after the LM337)?
/Per-Anders (my first name) or P-A as my friends call me |
#473 |
PA -- I found the problem -- the positive connection of the capacitor (C7) connection to the AD825 IN+ was faulty. It won't start if this connection isn't secure.
#474 |
here's an a.c. coupled scope-shot of the negative regulator output -- the transistors are MJD45H11 and MMBT5088 -- the trace has been averaged 16X for better clarity -- this is 10.4 millivolts RMS at 1 MHz -- there are no compensation capacitors on the AD825.
![]() Same thing with 300 pF compensation caps (WJ recommended 100pF, but I don't have any SMT 100pf's, drat!)
#475 |
Not nice - what's your final output cap? Type, value? I guess you have a prereg - does the prereg show something like this on its output? Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#476 |
the oscillation occurs with the LM337 pre-regulator -- the positive SR with no pre-regulator doesn't show any oscillation.
I am using Panasonic FC's 120u/25V. It isn't apparent from the Audio Elec article of 4/2000 whether WJ performed the same extensive testing on the pre-regulated SR as was the case in the 1995 series. I have to read the series again. Here's a snapshot of the SR output and the output of the LM337 -- "be some serious modulating going on down there Amos"
#477 |
The LM337 requires an output cap for stability, see DS. In the "Improved Positive / Negative Regulator" article of 2000, this is discussed on page 18, and takes the form of C1 and C12 of figs. 1 and 2.
#478 |
OK, I put a 120u/25V on the LM337 in put and that seems to have done the trick -- the board was being tested with rather long leads.
#479 |
In figure 4 of the AE article from 4/00 there is no bypass on R102 -- 825R from adjust to the output of the SR -- should this also be a.c. coupled to the output?
#480 |
Can you show us how you have made the grounding for all parts. This is very sensitive.
| Page generated in 2.56317 seconds (3.79% PHP - 96.21% MySQL) with 11 queries |
