Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th November 2005, 01:20 PM   #451
jackinnj's Avatar
Originally posted by Elso Kwak
Is that an advantage?
I was just stating the facts. and as we know the HFE can really bounce around a lot amongst a group of transistors.
Old 2nd January 2006, 02:11 PM   #452
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Re: SMT SuperRegulator
Originally posted by peranders
Jack, has your layout left your computer yet? Prototype is made?
Anything to show?
/Per-Anders (my first name) or P-A as my friends call me
Old 6th January 2006, 11:36 AM   #453
jackinnj's Avatar
PA
just got back from France --
I did some HV boards -- from an old (1982) Audio Amateur design and distributed at my cost (see group buys) -- but these super-reg boards are still in the cyber-stage.
Old 7th February 2006, 12:02 AM   #454
Onvinyl's Avatar
has someone tried and connected the superreg in a way that the pass transistor is longer a pass but a shunt?
I would love to hear if so.
The shunt trans. must be a pnp-device for the positive rail then, but how to connect the sense + feedback lines?
Rüdiger
Old 7th February 2006, 07:39 AM   #455
peranders's Avatar
I see no reason why you couldn't build a shunt regulator with the opamp fed from the regulated side.
Why do you ask? Anything special you want to use it for?
I have a hunch though that the PSRR will be _much_ less.
Why don't you simulate it and see if you can make it work.
Old 7th February 2006, 09:47 AM   #456
Onvinyl's Avatar
1) curiosity, see http://www.diyaudio.com/forums/showt...711#post135711
2) For the output stage in my phono (version of la boheme). I have a super reg (not ALW, but Jung-Didden 2002) for the output stage. It is a huge improvement compared with batteries. 'Holographic' sound and much more precision in stage, you really can tell where the instruments are placed. There is an issue, however: the bass is weak and fluffy, compared to an discrete output stage in borbely-style with simple regs.
Because the soldering iron heats up faster than the computer boots
No, because I'm not familiar with those programs. I tried, but it just ates time. I might draw an conceptual sketch tonight, and get some opinions here.
have a nice day,
Rüdiger
Old 7th February 2006, 01:12 PM   #457
jackinnj's Avatar
you need a slower computer or faster soldering station.
Old 7th February 2006, 03:19 PM   #458
Onvinyl's Avatar
Don't you mean the other way round?
Rüdiger
Old 7th February 2006, 08:27 PM   #459
peranders's Avatar
I really recommend that you test it. Many here have experience of LTSpice.
I have simulated three project with success, QRV-05 diamond buffer, QRV-06 current feedback amp and the last SST-01 softstart and for this LTSpice was _very_ helpful because the design is very unlinear and unpredictable. The simulation was nearly 100% exact!
You know you can also get distortion from the program!
You draw the schematic and when you are ready, just hook up a signal generator at the input then put an oscilloscope probe where you want the see the signal. Try as much as possible to get the simulation models for the parts you are going to use.
Old 7th February 2006, 08:44 PM   #460
Onvinyl's Avatar
Why? Are you referring to the bootstrapped op-amp arrangement?
However, the first real useful web-source concerning shunt regs (because it names design goals and tells us how to calculate relevant values), that I found just today, seems to imply that a top-notch shunt can't be achieved by simply swapping the super-regs pass-transistors from npn to pnp and await wonders.
older shunt reg. article by walt jung
Maybe the error-amp could stay, but we need a very high Hfe transistor arrangement.
Rüdiger
Page generated in 0.11653 seconds (77.12% PHP - 22.88% MySQL) with 11 queries
