#121 | |
Out to what power is easily achievable ?. Eric.
I believe not to believe in any fixed belief system. |
#122 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#123 | ||
Higher current means higher gm of the pass transistor means higher loop gain. Culd that be what you mean? Quote:
not a nuclear power station.
#124 |
diyAudio Retiree
Preloading regulators with a resistor is a VERY common technique and written about in TAA probably 15 years ago. This circuit was origionally developed as a regulator for low current preamp type circuits! Are Jan, Andy, and I the only ones that read all the TAA articles?
Christer, Not quite on the guess, but you getting warmer*. The other way to lower the output impedance instead of increasing the amount of negative feedback (or increasing the open loop voltage gain, that is) would be to do what? Peace, Fred *So is the regulator at increased current loading now that I think of it.... |
#125 |
diyAudio Retiree
"Fred, where does the picture come from?"
Sorry wrong schematic...... |
#126 | |||
why I asked about the origin of that schematic. ![]() Quote:
Vt/I if ignoring the source impedance, so higher current means lower open loop output impedance and, needless to say, lower closed loop output impedance. However, this is just the other side of the same coin as the gm stuff, so maybe that's not what you are after either. Quote:
#127 |
Where is the MOSFET version written up? How does
it compare with the original version? I'm having some trouble keeping up with the BJT variations. --Damon Hafler SE100 all-JFET preamp with Jung SR using AD797 working on bench supply using some flavor of Jung SR |
#128 |
diyAudio Retiree
"Let's see, the output impedance of an emitter follower is Vt/I if ignoring the source impedance, so higher current means lower open loop output impedance and, needless to say, lower closed loop output impedance.
Just det! Den skall inte spela någon roll spänning förstärkas Peace, Fred |
#129 | |
only the closed-loop gain that lowers the output impedance. Anyway, this was interesting. I hadn't thought about this before you challenged us with the question. |
#130 |
Köttbullar is swedish for meatballs. Isn't that the swedish chefs
specialty? It's been a long time since I watched the muppet show, though. BTW, the swedish chef doesn't sound very swedish at all to swedish ears, but I recently heard the story behind this character. It turns out there was a swedisch guy from a part of Sweden called Dalecarlia (Dalarna in swedish) who worked in the US. People from Dalecarlia sound a bit funny even to many of us swedes (funny in a nice way, I should add). Apparently he had quite a strong such accent also when speaking english which people found so funny that they decided to try imitating his way of speaking english when creating the chef. I suppose that is the reason he ended up as a swedish chef, and not some other arbitrary nationality. |
| Page generated in 0.13940 seconds (77.35% PHP - 22.65% MySQL) with 11 queries |
