Super Regulator, collecting the facts
Old 21st December 2012, 03:11 PM   #741
Jenyok is offline Jenyok  Russian Federation
One more interesting circuit.
Connect power of OpAmp to output positive and negative line of reg.
Old 21st December 2012, 05:31 PM   #742
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by Jenyok View Post
For example, simulate our Russian circuit and Jung super reg circuit in LTSpice or other simulate program and see result of simulation.
Every time I simulate it, it oscillates. I'd like to see a Bode plot from 10Hz to 10MHz. Consider some R between the collector of Q6 and ground (this has been mentioned before.)
With respect to PA's comment -- the faster the opamp, the lower the output impedance of the circuit.
Old 22nd December 2012, 12:06 AM   #743
martin clark is offline martin clark  Europe
..Though there's no use using a faster/slicker/more-fashionable opamp if you cannot stabilise the whole and keep it that way into the real-world load it drives (over the full range of expected load currents)...
Old 22nd December 2012, 02:05 AM   #744
jackinnj's Avatar
Agreed, we found that the AD825 sounded really nice in the "Improved" Jung regulator. Most of the time I've used the AD797AN in the "Original" (1995) regulator without problems, but sometimes it can get finicky. LME49710 sounded well and tested well.
Old 13th April 2013, 09:20 PM   #745
Flac is offline Flac  Netherlands
Hi Guys just read the article in linear audio about the different regulators.
Is there any way to get my hands on a PCB for the Jung/Didden regulator or evt. the Sjöstrom regulator. Preferably the first one. I'm looking for a +/- PSU of my audio path opamps. I was aming at the best avail. Any tip or link would be much appriciated.
TIA,
Peter.
Old 14th April 2013, 01:04 PM   #746
jackinnj's Avatar
The old colony boards are no longer available. Per Anders has a website -- and designed the Sjostrom boards.
Old 9th May 2013, 12:56 AM   #747
tonyptony is offline tonyptony  United States
Has anyone built and measured a Bobken regulator?
Old 1st June 2013, 10:30 AM   #748
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Superreg boards
I finally bit the bullet and layed out a set of superreg boards based on the original 1995 series articles, updated after Walt's 4/2000 article.
These are the successor boards to the ones Jack showed here.
All info is here: The Superregs
Let me know if there's anything I missed or got wrong.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 1st June 2013, 11:36 AM   #749
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Looks nice, thanks for the files.
Just wondering if you could split the pos and neg boards? Most of the time I only need the pos one, would be great to have separate boards so that we could just choose what we need.
Old 1st June 2013, 11:57 AM   #750
+1, and thanks for the work!
Super Regulator, collecting the factsHide this!Advertise here!
Copyright ©1999-2017 diyAudio
