Super Regulator, collecting the facts
Old 5th June 2012, 02:48 PM   #711
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The "pre-regulator" described in the follow up article Improved Positive/Negative Regulators Audio Electronics 4/00 will limit the current. The pre-regulator will raise the output impedance a bit, however.
http://waltjung.org/PDFs/Improved_PN_Regs.pdf
Old 6th June 2012, 10:14 AM   #712
Telstar is offline Telstar  Italy
Per, since you turned PMs off, could you send me a PM or email?
I need to ask you something about psu and the bridge PCBs i already have.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 25th June 2012, 07:44 AM   #713
KlipschKid is offline KlipschKid
Has anyone tried configuring an LM723 as a super-reg ? Any reason why it wouldn't work ?
Cheers
Tom
Old 25th June 2012, 08:46 AM   #714
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
No basic reason why it wouldn't work - it has all the necessary elements like reference and error amp.
However, from the specs like error amp BW and noise etc, the performance will most likely not be on a par with a superreg with carefully selected (active) devices.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 25th June 2012, 08:59 AM   #715
Thanks - the vref is 7.25V so I guess that'd suit 12v or higher supplies, and I could use an lm329 on the op amp output for that, or drop the voltage from the vref with the datasheet's suggested potential divider. I shall give it a try... it should work slightly better than the standard 723.
Tom
Old 25th June 2012, 07:50 PM   #716
WaltJ is offline WaltJ  United States
WaltJ's Avatar
Cheers
Tom
I'm not sure it would work without some additional hardware. The thing that differentiates the more advanced "super regs" is that the op amp + pass device actually regulates the output, and the op amp is fed directly from that output. I don't recall ever seeing a 723 circuit that does that.
I'm sure it could be done with added parts, however.
Walt Jung
Old 26th June 2012, 08:33 AM   #717
I'm quite happy to add a few parts. The vref is a buried zener and the noise is filtered with a low pass filter. Large caps (say over 5uF) in this filter cause the output to stay at vref, 7.25V, at start up, before dropping to the set output voltage. This would seem to lend itself to the super-regs start up conditions.
Anyway, I'll give it a try next week just out of curiosity.
Old 15th November 2012, 12:41 PM   #718
spartan is offline spartan
is the alwrs pcb still available anywhere?
Old 15th November 2012, 12:50 PM   #719
martin clark is offline martin clark  Europe
ALWSR boards? Yes, contact http://www.at-tunes.co.uk/
Old 15th November 2012, 12:53 PM   #720
thanks.
Super Regulator, collecting the factsHide this!Advertise here!
Copyright ©1999-2017 diyAudio
