Dimitris
I ve been messing around with LTspice to learn how to simulate things, and I came up with this schematic.
It is meant to provide +-10V @250mA more or less with a rough Hfe estimate on the transistor, but I m still very weak at taking account current limiting, loading etc. I had 4 sine voltages to simulate a 30V supply with ripple at various frequences. The output was pretty much very stable, although with similar parts, not the ones shown on this schematic. ![]() Any comments or suggestions are more than welcome. For the schematic or on how I can better simulate things on it. |
#2 |
So the transistors act as emitter-followers? Does Q2 have the emitter and collector swapped?
I'd take the easy way out and use an adjustable regulator like an LM317/337 or the LT improved versions, and add all the optional bypass caps. If it has to run from a wall-wart without a center tap, use an AC one and a 1/2 wave rectifier to get + and - rails. Maybe some RC filtering, or even an extra set of 3 terminal regulators to pre-regulate. |
#3 |
Just use the TPS7A4901 and its complement. Beats the LM317/337 combo but current limited to 150mA. Suits your needs but you gotta be able to solder it.
#4 |
Dimitris
dangus I think you are right... the pnp e and c are reversed...
![]() About the other suggestions, I have tried most of them at some point, and they all depend on a heavy filtering topology, super silent rectifiers and other stuff that in the end make things more complicated and difficult. The direct amplification of a super silent voltage reference seemed like a nice idea. Their nominal noise output is at the range of -120db (with similar ripple rejection at low frequencies with minor filtering) while the usual suspects (317 etc) give -80db ripple rejection at best on higher frequencies with huge filtering. I am not looking for an easy way out. I am looking to learn how to properly simulate stuff, and to design a super silent reg. |
#5 |
I would expect the models of complex IC assemblies to be very approximate.
Using that information I would come to the conclusion that many simulations will predict results that in practice cannot be achieved. |
#6 |
Ripple isn't actually a sine wave. Try something like this altering the values to suit,
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Best low noise regulator? | analog_sa | Power Supplies | 469 | 14th January 2013 12:44 PM |
| Simple Low Noise Voltage Regulator? | lxmyers | Power Supplies | 16 | 27th November 2011 08:24 PM |
| Low Noise Linear regulator power supply | leonm12 | Power Supplies | 13 | 13th June 2011 03:50 PM |
| Low noise DC regulator problem | mravlca | Power Supplies | 14 | 3rd February 2010 02:27 PM |
| ForSale: LT1085CT Low noise Regulator | tone | Swap Meet | 0 | 10th September 2003 06:22 AM |
