Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st March 2012, 11:12 AM   #1
b1o2r3i4s5's Avatar
Default DC-DC converter for vacuum tube heaters
Hi, I am currently building a Vacuum tube headphone amp with 160V DC rails, and planning to power the tube heaters using a switching DC-DC converter from the 160V rail, since the heaters only need 3-4W and transformers are hard for me to get. I was planning to use a non-isolated Buck Converter but they are usually used at low voltages, so what i wanted to know is:
1. is it okay to use a buck converter to step down from 160V to 12.6
2. will it cause any problems if i connect a DC-DC converter to my 160V supply rails and could i power the tube heaters with it
My power transformer is rated 110VAC 50VA output. The power supply bypass capacitor is 2200uF.
Old 21st March 2012, 01:03 PM   #2
Send a message via AIM to DigitalJunkie
A small 12V SMPS (wallwart/charger) for a cellphone,or something should work okay from 160Vdc. Most of them just rectify the incoming ~120Vac to 160Vdc anyways. Just find one with enough current capacity to power the heaters.
Old 21st March 2012, 01:17 PM   #3
jackinnj's Avatar
If it's a wall wart charger use a low dropout regulator afterward to clean up some of the switching noise.
You can use the Supertex LR8N3 to drive the base of a high voltage NPN transistor -- this device was designed to provide auxiliary power for SMPS circuits like off-line switching supplies. It's available in the US from Mouser, don't know about HK.
Old 21st March 2012, 01:51 PM   #4
b1o2r3i4s5's Avatar
Thanks A lot!!! I Used a universal (110V/220V) 12V SMPS charger and it works perfectly without inducing audible noise to the amp.
6N3 Tube Preamp with DC-DC converter nige838 Tubes / Valves 82 17th March 2013 07:10 AM
Tube heaters AC or DC? soundbadger Tubes / Valves 112 24th October 2012 04:46 PM
DC Tube Heaters Bengali Tubes / Valves 9 25th March 2011 03:50 PM
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 03:48 AM
DC/DC converter to power tube amp? needtubes Tubes / Valves 2 24th June 2005 02:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
