how to eliminates AC spikes
Old 18th March 2012, 02:41 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Question how to eliminates AC spikes
I have a dedicated/separated AC mains for my audio system, when I use my BIII DAC I have AC spikes that causes dropouts, I know that AC spikes are caused by central heating when starts the heating, I remember that I can connect 01,uF 400VAC in the AC inlet where is connected the central heating but don't remember if I have to connected between hot & neutral or other way, could you help me?
Old 18th March 2012, 02:51 PM   #2
DF96 is offline DF96  England
If the spikes are that bad you ought to think about a proper filter rather than just a cap.
Are you sure it is a spike, and not a short brownout?
Old 18th March 2012, 03:19 PM   #3
Yes I'm sure it's an AC spike because occurs when I hear the temperature controller central heating starts. I use John's Risch AC power conditioner filter. What's a brownout?
Old 18th March 2012, 03:36 PM   #4
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
A brownout is when you have a voltage drop on your main A.C. line. A blackout is zero voltage - a brown out would be like dropping the voltage of a 120 VAC line down to 80 - 100 volts. Often a large electrical load being switched on will cause this for a short duration.
We used MOV varistors to protect against dangerous spikes http://electroschematics.com/5224/metal-oxide-varistor/
But for line spikes in critical situations we would use isolation transformers.
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 18th March 2012, 03:38 PM   #5
A brownout is a temporary dip in mains voltage, sometimes caused by the switch-on surge in an item on the same feeder if the supply has too high a resistance. Spikes are more likely when something switches off.
Old 18th March 2012, 03:41 PM   #6
Isn't a brownout: I measured AC with my DMM always 231VAC, the BIII unlock.
Old 18th March 2012, 03:48 PM   #7
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
You need a proper mains filter with L and C.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Old 18th March 2012, 03:53 PM   #8
wwenze is offline wwenze  Singapore
You can chain multiple AC line filters.
But if you can, do your modifications on the DC side of the equipment's power supply instead. Besides, from your previous threads, it seems that it is your DAC that isn't reliable to start with. Do you get the same problem with other products?
Old 18th March 2012, 03:55 PM   #9
Jon Risch's AC Power Line Filter & Surge Suppresor
File Type: jpg Jon Risch's AC Power Line Filter & Surge Suppresor.jpg (287.7 KB, 425 views)
Old 18th March 2012, 04:01 PM   #10
Page 2
File Type: jpg Jon Risch's AC Power Line Filter & Surge Suppresor 2.jpg (409.4 KB, 407 views)
how to eliminates AC spikesHide this!Advertise here!
Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! Ulisez Power Supplies 13 23rd November 2010 07:42 AM
Have 7v ac need 6.3v ac, need simple ideer heinrichs Power Supplies 7 17th June 2010 02:46 PM
WTB: Analog AC Ammeter - AC Voltmeter - Panel Mount dBfreak Swap Meet 1 16th March 2007 11:41 PM
PS question- Need to get 20V AC from 60V AC - w/o Trafo lgreen Pass Labs 9 2nd January 2004 11:31 AM
HUBBELL IG3800 clones? AC sockets /AC wire jasonruiz Parts 5 25th April 2003 11:21 PM
Copyright ©1999-2017 diyAudio
