PS for a MKII tripath TA2024 Amp 2x15W
Old 15th March 2012, 02:10 PM   #1
obrah is offline obrah  Denmark
Default PS for a MKII tripath TA2024 Amp 2x15W
Hi there
Just got my tripath amps today, and cant wait to get them working!
now i need a powersupply.
ive found this
HN-POWER HNP18-120 PLUG-POW. SUPP. 18W | Mains Adapters with Fixed Voltage Mains Adapters / Power Supplies Power Supplies & Mains Adapters Batteries/Power | Conrad Electronic SE - Mains Adapters with Fixed Voltage
and this
Voltcraft FPPS 12-12V 18W power supply | Mains Adapters with Fixed Voltage Mains Adapters / Power Supplies Power Supplies & Mains Adapters Batteries/Power | Conrad Electronic SE - Mains Adapters with Fixed Voltage
The reason im asking is that, ive read here on the forum that the PS is important considering soundquality, and i really wanna get the best SQ i can!
So do you think one of these PS's will do or can you recommend something else?
Best regards
Andreas
Old 18th March 2012, 12:38 PM   #2
epicyclic is offline epicyclic  United Kingdom
Try posting in class D
Old 19th March 2012, 11:59 AM   #3
If you want the best performance from this chip you should stay below:-
6W into 8 ohms on both channels
10W into 4 ohms on both channels
If your speakers maintain 8 ohms and you stick to 2x6W then the linked to power supplies should be OK
If the speakers are 4 ohms you need a 30W output power supply
If you want max output into 4 ohms you will need a 45W power supply.
PS this information i have gleaned/calculated from the data sheet , i have no hands on experience with this chip .
Old 21st March 2012, 06:32 PM   #4
dangus is offline dangus  Canada
I'm powering a TA2024 amp from a "brick" 12V 3A Polaroid power adapter that I found in a gravel pit (probably from a scanner or monitor). I don't hear any audible noise. I've picked up similar adapters from thrift stores for a few dollars each, and a couple of Xantrex 12V/5A from a liquidation store that were made to power thermoelectric picnic coolers. Or search eBay for 12V (3A,4A,5A) supply and you'll find some for under $10 shipped. Thrift store supplies may be higher quality since they were originally purchased by companies with reputations.
PS for a MKII tripath TA2024 Amp 2x15WHide this!Advertise here!
Using computer PSU with Arjen's Ta2024 mkII zorobabel Power Supplies 3 10th March 2012 06:08 AM
Arjen Helder TA2024 MKII Feedback Resistors johnviera Class D 8 14th September 2011 02:19 PM
My Sure TA2024 Tripath Arrived! ricortes Class D 0 7th November 2009 06:53 AM
Tripath RB-TA2024 Board Q's HaLo6 Class D 4 4th June 2009 02:32 AM
New kit with the Tripath TA2024 kanaddict Class D 10 26th July 2005 10:14 PM
