diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Ringing/Oscillation in amplified zener sim (http://www.diyaudio.com/forums/power-supplies/208471-ringing-oscillation-amplified-zener-sim.html)
aborgman 9th March 2012 06:48 PM
So I'm using an amplified zener on the low side of a full bridge rectifier to drop ~200V off a HV supply.
http://i227.photobucket.com/albums/d...es/circuit.jpg
The output voltage looks good, and is coming right where I want it.
http://i227.photobucket.com/albums/d...ut_voltage.jpg
The issue is (or maybe isn't) ringing at the output of the bridge caused by the amplified zener. Here is what I'm seeing at the output of the bridge:
http://i227.photobucket.com/albums/d...bridge_out.jpg
Zoom -
http://i227.photobucket.com/albums/d..._out_zoom1.jpg
Zoom to single cycle -
http://i227.photobucket.com/albums/d..._out_zoom2.jpg
Thoughts?
Is the ringing real, or a just a simulation/model artifact?
If it's real - thoughts on getting rid of it?
Elvee 9th March 2012 07:22 PM
First thing to do is to test your pseudo zener in isolation: when it's hooked up in a circuit with AC sources, rectifier bridges and various components like inductors, it's difficult to know exactly what's going on.
With simulation, it's the easiest thing of the world to do, so you have no excuse.
Then my prime suspect would be L1: I have a suspicion it isn't damped, and in sim that would mean a very high Q.
Even in reality, such an arrangement could create funny effects.
First make an AC analysis on your zener, using the actual static conditions: this will show any possible quirk in the impedance curve
RJM1 10th March 2012 06:12 AM
If you add a 1F capacitor from D3, D4 cathode to ground, this should stop your ringing.
You could also add a resistor in series with the 1F capacitor of somewhere about 33 to 100 ohms to reduce the turn on surge and still eliminate the ringing.
You can simulate your circuit without your amplified zener and get the same ringing.
jan.didden 10th March 2012 09:24 AM
Originally Posted by Elvee (http://www.diyaudio.com/forums/showthread.php?p=2939768#post2939768)
I agree. There's an undamped L-C that would ring.
Why are R1, R2, R3 so large? What is this circuit for?
jan didden
RJM1 10th March 2012 10:52 AM
Tube plate supply my guess with the 6H inductor
aborgman 10th March 2012 01:40 PM
Originally Posted by janneman (http://www.diyaudio.com/forums/showthread.php?p=2940395#post2940395)
Yep.
Putting a filter cap ahead of the inductor totally damps the flyback oscillation. I'm actually not sure WHY I didn't have one originally.
B+ supply in a tube preamp. R1/R2 are filter/dropping resistors and R3 is the load.
Basically B+ is only going to the plates of 2x6SL7 (4 sections total) and at DC it is only drawing ~3mA of total current.
So... 500VCT transformer and I need ~410VDC @ 3mA.
gootee 11th March 2012 03:00 AM
Capacitors don't do damping. Resistors do damping.
gootee 11th March 2012 03:37 AM
Practical snubber design procedure is at post 292, here:
http://www.diyaudio.com/forums/power...ml#post2828689
Copyright 1999-2017 diyAudio
