My new psu
My new psu
Old 9th March 2012, 03:26 AM   #1
lukaas is offline lukaas  Malaysia
Send a message via Yahoo to lukaas
Default My new psu
Hey guys,
I'm fairly new to electronic hobbyist, but not a stranger to this field.
I have an unregulated 12V/14V 20Amp power supply unit. My plan was to hook it up to my extra car power amp and play it in my home.
But after recent readings, I come to conclusion that my psu amperage will not be sufficient to handle the loads.
So, my question is, how do I improve the psu? without changing the main transformer unit... :-)
Old 9th March 2012, 03:30 AM   #2
sawreyrw is offline sawreyrw  United States
If the load is greater than the transformer rating, you must replace the transformer.
Old 9th March 2012, 04:13 AM   #3
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
My new psu
yes, your traffo must be able to handle the load...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th March 2012, 06:28 AM   #4
oo.. ok .. thanx all for the replies ..
Old 9th March 2012, 01:46 PM   #5
It is usual for the transformer VA to be rated at 1times to 2times the maximum power output of the amplifier.
If the manufacturer of the power amplifier is not telling lies then a 260VA transformer can power a range of amplifiers from 130W to 260W.
But that same transformer can still allow a much wider range of amplifier powers to operate without damage. Probably from 10W to 500W with care.
regards Andrew T.
Old 9th March 2012, 02:08 PM   #6
R.I.P.
There is nothing stopping it working well unless you connect it to a real
1KW car amplifier, connect that to a load of loudspeakers and then run
it a full volume with test signals and wait to see what blows up first .....
With a decent capacitor bank it will be fine with any sensible car amplifier.
rgds, sreten.
Old 13th March 2012, 03:06 AM   #7
oo.. ok.. thanx for all the replies guys
My new psuHide this!Advertise here!
PSU Model for a 9V PSU, parts question jamesdb Power Supplies 11 4th December 2011 10:38 AM
briangt PSU 1 transformer, 2 PSU, how to? sansbury Chip Amps 30 28th March 2010 08:26 PM
Quieting a Switching PSU? or easier to replace it with a linear PSU? at77 Power Supplies 23 18th March 2010 06:46 AM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 11:45 PM
pre-PSU for cuno snoeren XO PSU? pukka Digital Source 0 30th December 2003 03:39 PM
