Hi folks,
I need to rig up a small PSU giving 8V using a 7808 and giving 5V using a LT3080.
I was wondering if I should take the V+ from the 7808 to feed the LT3030, using the 7808 as a pre-regulator or rather feed them both from the unregulated 12V supply.
Benefits / Drawbacks ?
I don't feel like doing a sim on it, so any advice is appreciated.
TIA,
Max
TIA,
Max
Well, I'd say almost nothing... if I can say so.
5V will be feeding 2 TORX Toslink receivers and 1 TOTX Toslink emitter, 8V will be used for switchig a source selection relais...
I expect the total current drawn to be under 100mA. If the values are crucial I can dig out the datasheets.
Max
Max
I just tried running a Preamp(12vDC regulated with LM317) and a Channel switching curcuit that uses relays (5vDC regulated with LM7805)) from the same 12v AC Transformer and ran into problems right off the bat ...... When I enganged Relay curcuit I would get a pop in the Audio of the pre amp , When I used a seperate transformer for each the pop went away ......
Hopefully you don"t have the same problem ......
