Transformer wiring - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th March 2012, 02:40 PM   #1
Calamaro's Avatar
Default Transformer wiring
Just scavanged this transformer from an old tube radio and I don't understand its wiring.
Primary:
these were connected to voltage selector:
blue 220v
green 160v
black 145v
red 125 v
yellow 110v
but what about brown and 2 white?
Secondary:
I've checked when still working in the device
2 red 400v
2 white 6v
what about black?
I wonder if there is some kind of colour code (I read red for anode and white for heaters) or how calculate unknow values...
Old 4th March 2012, 04:05 PM   #2
RJM1 is offline RJM1  United States
The black is probably the center tap for the red wires and was connected to ground. You can verify this with an ohm meter, the resistance between the black and either red wire should be half of the resistance of that between the two red wires.
Old 4th March 2012, 04:10 PM   #3
Calamaro's Avatar
I measured 300ohm and 164 ohm so it is 400-0-400.
Thanks! Any idea about the other wires?
Old 4th March 2012, 10:05 PM   #4
Are all the "primary" wires on the same winding?
Are all the secondary wires on the same winding?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th March 2012, 10:34 PM   #5
Calamaro's Avatar
I really don't know
How can I check? Are you suggesting that white unknow wires are another 6,3v secondary?
And: If blue wire is one of primary wires for 220v, which one is the other one?
Old 5th March 2012, 09:34 AM   #6
BE VERY CAREFUL !
If there is anything in the following paragraphs that is not clear then ask again before you guess and kill yourself.
Insert each end into a separate terminal of an insulated terminal block.
The screws will ensure a reliable contact through the enamel insulation.
Use an ohm-meter to check check for continuity from all the ends to all the others.
Label each continuous set. They are one winding.
Each winding could have more than 2 ends. Sometimes an adjustment tap (or taps) just a few %, more or less, sometimes a tap at the centre (50% to either side).
Then measure the resistance of each part of the winding from tap to tap.
This will let you identify the "ends" of the windings and the intermediate tapping points.
Now select the longest "primary" tappings. Power up via a bulb tester.
Measure the voltage at each of the secondary windings and at any intermediate taps.
regards Andrew T.
Old 5th March 2012, 10:10 AM   #7
DF96 is offline DF96  England
The whites could be a separate heater winding for a rectifier, either 6.3V or 5V (depending on the age of the set). Newer rectifiers tend to have an isolated heater, just like other valves, but a separate heater winding can still help with valve lifetime.
Old 5th March 2012, 05:19 PM   #8
Calamaro's Avatar
I'v e checked for continuity.
"Primary" wires: continuity between
-green
-black
-red
-yellow
-brown
no blue and no 2 white
continuity between 2 white
"seconday" wires:
2 red wires don't have continuity at all
same for black wire
Hope this means something to you
Some resistance values:
between:
brown and yellow 9
brown and red 12
brown and black 16
brown and green 21
brown and blue 59
between 2 white "primary" side 5
between 2 white "secondary" side 5
between 2 red "secondary" side 314
between one red and black 164
Once again I hope this means something to you
Old 7th March 2012, 09:17 PM   #9
Calamaro's Avatar
Default Fundamental question
Fundamental question:
which wires should be connected to mains?
Old 8th March 2012, 08:05 AM   #10
Is blue isolated from every other wire end?
If so then it could be an electrostatic screen between primary and secondary.
Can you tell if the brown wire is wound closest to the core?
That could be the "end tapping" of the primary winding.
You need to find the other "end tapping".
It may be the blue wire showing 59r
Check the resistance from blue to all the other primary wires. Are any more than 59r?
Check from Yellow to all the other primary wires. Are any more than 59r?
Once you know that you have found the highest resistance winding then it is safe to assume it is the main connection for power in.
With all the wires still safely screwed into their separate terminals, connect the longest winding via the bulb tester to mains power.
Stand back and switch on.
Did the bulb glow, or flash, or nothing at all, or go bright. Stop there and report back.
Be very careful !!!!
The reds wires may be at very high AC voltage.
regards Andrew T.
Transformer wiring (Need Help) fingerboy21 Tubes / Valves 6 13th April 2011 03:15 AM
Wiring Buck Transformer with GE transformer Help! HP8903B Tubes / Valves 20 8th January 2011 08:52 PM
How to wiring the transformer olaychang Tubes / Valves 7 2nd February 2009 05:07 AM
transformer wiring homertooties Power Supplies 3 12th June 2007 08:19 AM
Transformer Wiring? Killjoy99 Parts 4 2nd October 2004 11:00 PM
Copyright 1999-2017 diyAudio
