Noise problem - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th March 2012, 06:53 AM   #1
Default Noise problem
I have a noise from speaker (ZZZZZZZZZZZZZZZ) when ever someone turn on the heater shower (like this Instant Water Heater Shower
I open the amp up and the toroidal transformers (CD player, DAC and Amp) are giving a hum noise when every that happen.
When the heater shower is off , it will be back to normal.
Is there a way to overcome this?
Thanks.
Old 4th March 2012, 07:06 AM   #2
Just to clarify the toroidal is normally quiet till you turn on the shower.
Is it a diy amp that you can more easily modify.
Old 4th March 2012, 07:16 AM   #3
Ya, normally it is quite. It is a DIY tripath amp.
Old 4th March 2012, 08:40 AM   #4
Try searching this site with " noise on transformer"
And/or go to www.sound.westhost.com/articles/xfmr-dc.htm
Old 4th March 2012, 08:51 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Suppose the heater takes power from the line asymetrically, that would leave a DC component on the mains. Torodial transformers do not like this and will buzz, partly due to having no gap in the core and a high flux density. Lots of folks use a DC line filter to prevent this. Search the forum for the circuit. There are other appliances that can cause this to happen, microwave ovens for one, & powerful SMPS circuits can also contaminate a local mains circuit.
All the trouble I've ever been in started out as fun......
Old 4th March 2012, 01:44 PM   #6
Thank you.
Old 5th March 2012, 03:22 AM   #7
After some search, found a few circuit that can be done pretty quick and I have parts for it Variations of DC Main Filter against buzzing Toroid Transformers - what is the right? post 80
I done up 4 caps (10000uf 16v) with a bridge rectifier, connect it to the power inlet to the amp. It didn't works, noise is still there when heater is on. I will order some parts to try the next one.
noise problem vidc Chip Amps 2 5th January 2010 05:51 PM
SMPS noise problem Nuuk Digital Source 8 4th July 2006 02:02 PM
Noise Problem. raveenvijendren Solid State 0 14th November 2005 06:03 AM
Noise Problem Jackson Yaya Solid State 4 6th June 2005 06:08 PM
noise problem danyel Chip Amps 3 23rd February 2005 10:59 AM
Copyright 1999-2017 diyAudio
